Limited Slip
Old Jul 5, 2003 | 09:19 AM
OldeBoy's Avatar
OldeBoy
Question Limited Slip
I was wondering how I can tell if my 2002 XLT 4X4 has a limited slip axle without jacking it up and turning the wheels. Is there a code on the back of the differential I can read to find out. Thanks in advance.
Old Jul 5, 2003 | 09:43 AM
Chris_ce's Avatar
Chris_ce
Limited Slip
there is a code on your door jamb and should be a section on towing in your manual to tell what the code means
Old Jul 5, 2003 | 10:01 AM
OldeBoy's Avatar
OldeBoy
Limited Slip
I found the codes on the doorjamb but did not find anything in the manual about what the codes mean.
Old Jul 5, 2003 | 01:51 PM
Chris_ce's Avatar
Chris_ce
Limited Slip
post your numbers someone will help
Old Jul 6, 2003 | 03:06 PM
OldeBoy's Avatar
OldeBoy
Limited Slip
The tag on the doorjamb states -Axle/ 97-
what does this mean? What axle ratio is it?
What other info off the tag do you need?
Thanks in advance.
Old Jul 6, 2003 | 04:14 PM
OldeBoy's Avatar
OldeBoy
Limited Slip
Thanks for the link.
Old Aug 4, 2003 | 02:09 PM
03EDGE's Avatar
03EDGE
Limited Slip
There is a tag on the rear differential that is attatched to a bolt on the rear cover. It should have, (for ex: 3L73 8.8) The top number starting at the bolt will be the gear ratio. If it has and L between the first numer and the second it is a locking rear. Good luck!
Old Aug 4, 2003 | 03:19 PM
WXboy's Avatar
WXboy
Limited Slip
Yours says "97"? That means you do not have a limited slip. If it is limited slip, the code will be a number and letter combination. For instance, I think mine is "R7" or something like that.
Old Aug 4, 2003 | 07:34 PM
Rockledge's Avatar
Rockledge
Limited Slip
That's right WX. Look here: 1992-2003 Ford Ranger Axle Codes
Old Aug 4, 2003 | 07:41 PM
AG4.0's Avatar
AG4.0
Limited Slip
so I just did a check of my axle, R6, and it says limited slip 3.73, but it doesn't act like a limited slip, could it be mine is just bad. In 2H I can easily break just one tire loose on dry pavement.
Old Aug 4, 2003 | 08:09 PM
Ken00's Avatar
Ken00
Limited Slip
The clutch packs are worn out I bet.
Old Aug 4, 2003 | 09:40 PM
AG4.0's Avatar
AG4.0
Limited Slip
I would believe that, can tell the previous owner of my truck used it pretty good, lots of charachter to it, and some welds on the exhaust where it looks like it must have been busted at some point. Still runs like a champ, though. Is it very expensive to get the clutch packs replaced or would I be best getting a whole new traction system.
Rockledge's Avatar
Rockledge
Limited Slip
Probably would be worth changing the fluid in the rear diff to see if it would help...
Old Aug 5, 2003 | 06:56 PM
Ken00's Avatar
Ken00
Limited Slip
Sorry, don't know the cost. If you change the fluid you need to add friction modifier.
