Pulley system?
Old Apr 24, 2014 | 09:26 PM
polarspeed's Avatar
polarspeed
Pulley system?
Hello,
I am in the processes of getting ready for a heart transplant for my truck. I just got a 1998 explorer 5.0 with 88K and have been tearing into it. I am going to be making separate threads for each question. My goal is to do my best to have high quality parts that don't break the budget. I want to buy from US manufacturers when possible even if it comes with a premium.
My second question is regarding the CVF racing Beast serpentine conversion. I am hoping to use the EDIS-8 system while converting the 5.0 to carb with the weiand stealth intake and Holley street avenger 570 carb. I am going to upgrade the valve springs (LUN-73100K2) when I freshen the heads and upgrade the cam to a Lunati Voodoo cam (LUN-20350710). I want to use a DIY 36-1 trigger wheel between the balancer and pulley. This lead me to the CVF Racing front set up. I am only going to have a mech water pump, alternator and would like to plan for an AC compressor for future upgrades.
This is the system that I had in mind and wanted to get feedback.
Ford 302 Windsor Serpentine Pulley System (302W) - AC and Alternator - No power steering
This system is made in the USA, is reasonably priced and the support is really great and responsive. Lunati has also been very helpful.
Thanks again,
Steve
Old Apr 25, 2014 | 10:19 PM
TireDood's Avatar
TireDood
I have an AC compressor bracket, crank pulley, and water pump pulley that I got from CVF. everything fit well and looks good. I bought from them for the same reason... USA made, and the company is owned by a veteran.
Old Apr 26, 2014 | 08:27 AM
ranger pat's Avatar
ranger pat
Veteran: Navy
The 98 Explorer 5.0L already has a "short shaft" water pump and serpentine belt system. There is an available bolt on kit to eliminate the power steering pump and or a/c compressor. Why spend big bucks to change from one serpentine system to another?
Old Apr 26, 2014 | 10:26 AM
ChuckRob's Avatar
ChuckRob
That is exactly what I was thinking. With a fat fendered truck most of the belt system if hard to see without laying on the fender and the stock system works just fine. I have the AC eliminator kit laying around the shop somewhere.
Old Apr 26, 2014 | 07:10 PM
polarspeed's Avatar
polarspeed
I would love to know how to get my hands on the Power steering elimination kit. The only thing about the explorer brackets is that they are UGLY. Anyone have any pics of how to beautify them? Thanks, Steve
Old Apr 29, 2014 | 06:21 PM
polarspeed's Avatar
polarspeed
I just saw a friend who is rebuilding his 98 mustang and he took the serpentine brackets, beadblasted, primered and painted them with primer followed by gloss black. They looked really sharp. I will give it a shot and then I will show you guys how it turns out. Thanks for pushing me to a cheaper and more creative option.
Steve
Old Apr 29, 2014 | 10:07 PM
Project-55's Avatar
Project-55
"If" you are needing all the components tucked in nice and tight, You might want to check out Rocky Hinge, I put their system on the 350 cid engine we stuffed in Jon's 1950 F1 and it worked perfectly, everything fits between the frame rails with clearance to spare.
But, if you can do it on the cheap,,,,,even better.
Old Jul 17, 2014 | 08:54 PM
polarspeed's Avatar
polarspeed
I am so glad that I posted here and I wanted to share what I have done with my salvaged motor. I have blasted and painted the brackets and eliminated both the PS pump and the AC. I still retain the option to add AC without significant reengineering...just need more $$$. Here is the set up.
New motor - 1998 Ford Explorer 5.0. New Cam and valve springs. Weiand Stealth intake and Edelbrock 600cfm 4-barrel (to be added). Will retain the crank trigger and use the EDIS-8 module and the megajolt box for computer controlled ignition.
Let me know what you think.
Here is the radiator set up that I have prepped to go into ol' blue.
new radiator set up - Winner Racing Al 3-core with welder Joe's shroud. 16" electric fan and a billet overflow tank. Will use the Megajolt to control the fan with the intake temp sensor.
Thanks again for all of your help.
Steve
Old Jul 17, 2014 | 09:06 PM
polarspeed's Avatar
polarspeed
Oh yeah... This is where it started.
Just back from the salvage shop.
Steve
fordka
Mar 28, 2014 07:32 AM
Holehawgg
Mar 15, 2014 09:44 PM
54 on the floor
May 4, 2005 08:40 AM
William
Oct 25, 2002 03:58 PM
F250Pilot
Jul 1, 2001 06:36 AM
