fuel lines?
Old Apr 22, 2014 | 12:08 PM
FF34's Avatar
FF34
fuel lines?
Ok I got a question, when my 7.3 sits for more than about 2 hrs I have to hold down the gas peddle when I start it so it gets fuel to fire. The longer it has sat the more cranking it takes and I have to pump the peddle a few times. Is this because my lines are leaking or is air getting in or something like that? Thanks for any input.
Old Apr 22, 2014 | 12:21 PM
fordtruckman838's Avatar
fordtruckman838
Yep, I think you are on to the right idea. Sounds like you need a new return line kit. While you are at it check the fuel heater also.
Old Apr 22, 2014 | 08:10 PM
86f350's Avatar
86f350
I second the return line kit. Just fought this battle on my 6.9 after replacing the fuel tank.
Old Apr 23, 2014 | 12:07 AM
FF34's Avatar
FF34
Thanks guys! Guess I'll look into a return line kit. Any suggestions on which one to get?
Old Apr 23, 2014 | 06:56 AM
fuzzy1626's Avatar
fuzzy1626
Is it hard to start first start of the day also, or only after it has been run and shut off?
Old Apr 23, 2014 | 10:01 AM
FF34's Avatar
FF34
It's anytime it has sat for more than a couple hrs without being plugged in. If its been plugged in it starts just fine even after sitting overnight.
Old Apr 23, 2014 | 06:25 PM
fuzzy1626's Avatar
fuzzy1626
Sounds like you have a glow plug issue.
Old Apr 24, 2014 | 11:10 PM
speedwrench72's Avatar
speedwrench72
you answered your own question it starts right up when plugged in over night....why would the fuel not drain away from the ip when plugged in....it is a bad gp controller, some times they go bad as to only heat the plugs, for about 3-4 seconds each time you turn the key off and back on...so try and turn the key on and off 5 times, then crank it. if it starts right up it is the controller. and or if it allways starts when pluged in...the WTS light may only blink on also if the controller is bad or if more then one gp is bad.
Old Apr 24, 2014 | 11:15 PM
FF34's Avatar
FF34
Sweet ill test out the glow plug controller and if that's it I'm gonna hook up a Manual one. Wanted to do that anyway! All my glow plugs are good I checked them already...
tlk401
1983 - 2012 Ranger & B-Series
Dec 13, 2022 02:50 AM
Suomi Powerstroke
Nov 16, 2009 10:10 AM
investedocean
Jun 23, 2008 09:41 PM
lartross
Sep 10, 2006 11:13 AM
salewit
Jun 26, 2006 10:52 AM
