What's wrong with this engine?
Old Apr 20, 2014 | 11:02 PM
tomhilmes's Avatar
tomhilmes
Pulled the head off my 4.9. Every intake seat visibily cracked. Valve heads are all white. Safe to put a reman head on it or should it all come down to check block as well? Yes, it did get really hot once upon a time.
Got the engine on the stand but thinking a good used engine might be a good move. This is an occasional driver just used for hauling. What would you do?
Old Apr 20, 2014 | 11:23 PM
Crewcabber's Avatar
Crewcabber
If its already out and on the stand pull it down. How many miles does it have on it. If it's got high mileage it's not worth throwing a new head on it and have the bottom end go.
If everything was white I would say either overheated or running to lean.
Old Apr 21, 2014 | 08:31 AM
Conanski's Avatar
Conanski
That engine was running excessively lean so you have a fueling issue that needs to be fixed.
sdiesel
51
Sep 28, 2017 08:40 AM
pineconeford
39
Dec 19, 2012 05:37 PM
71dusterjon
69
Apr 22, 2009 12:26 AM
4.9inline6
Jan 19, 2006 10:17 PM
duc_grrl
Dec 23, 2004 06:07 AM
