12 Volt conversion generator
Old Jul 4, 2003 | 09:32 PM
Cdn Eh's Avatar
Cdn Eh
had a rebuilder tell me that i could use my orginal 6 volt generator as it is when converting to 12 volt.anybody done or
heard this before.will it work ? 48merc flathead 239
tnxs Ron
Old Jul 4, 2003 | 11:48 PM
angus's Avatar
angus
My hunch is that you might get enough voltage at high RPMs, but there wouldn't be any charging at idle. Or, I could be wrong: maybe the higher field voltage will coax more volts and amps out of the generator. You'd definitely have to change the regulator.
Last time I went looking for a 12V generator at a junkyard there were plenty to choose from for around $20 apiece, so why not just put a 12V generator in?
Old Jul 5, 2003 | 11:36 AM
Cdn Eh's Avatar
Cdn Eh
I was just wondering if it would work. i havent got around to the
junkyards yet . still trying to decide if i will convert it over.thanks
for the reply.
Old Jul 6, 2003 | 12:16 PM
johann5's Avatar
johann5
I replaced the field coils inside my 6V generator to convert it to 12V. Works great. Also needed regulator, guage modifications and bunches of bulbs, etc, etc, but I found it well worth it. Looks original and no new brackets or belts to mess with.
J
Old Jul 6, 2003 | 06:58 PM
Cdn Eh's Avatar
Cdn Eh
thanks johann5 this sounds like the way to go everything still looking stock.
