Trans fluid
Old Apr 19, 2014 | 04:00 PM
Iaff113's Avatar
Iaff113
Trans fluid
So I dropped and replaced fluid and filter the other night. Guess I didn't pay attention and fluid is reading high on the dip stick. It's not crazy high, maybe half quart. Should I drop the fluid again or can I wait till I was Gona do it in 1000 miles
Old Apr 19, 2014 | 04:19 PM
retiredinstructor's Avatar
retiredinstructor
if it is over full definetly lower it otherwis airation can occur.make sure not overful hot if full cold it will expand when hot and be overfull
Old Apr 19, 2014 | 04:27 PM
Iaff113's Avatar
Iaff113
Yeah it's Defiantly over full hot. I wasn't sure of it was bad for it. I will drop the fluid tonight then
Old Apr 19, 2014 | 04:39 PM
Iaff113's Avatar
Iaff113
Just drained it to the middle of the full line. So I'm guessing that should be ok
Old Apr 19, 2014 | 06:33 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
That will be fine.
Old Apr 19, 2014 | 07:15 PM
Ford_Fan1's Avatar
Ford_Fan1
Not to derail, but when after it is drained and you start it up and put it in neutral for the first time should it be filled all the way to the hot line or only to the cold line? I have always been mixed up as to whether hot fill means if you live in a hot climate fill to that line or the fluid should be there when the engine is hot.
Old Apr 19, 2014 | 10:06 PM
Mark Kovalsky
Hot fill means checked when the transmission is at operating temperature. The cold fill line is for people that don't want to check the transmission fluid properly. Don't ever use the cold fill line for ANYTHING.
Old Apr 20, 2014 | 11:55 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
Next time measure the amt you removed and put that much in.... then run until it's up to operating temp and then recheck it.
fordman19762003
Jun 4, 2018 07:58 AM
dan8052
Aug 16, 2013 01:23 PM
Bucky3d
Feb 23, 2008 08:42 AM
priv8pilot
Nov 18, 2006 08:56 AM
mwh
2004 - 2008 F150
Jul 11, 2004 12:34 PM
