Gear Swap....recommendations
Old Apr 18, 2014 | 08:13 PM
dvldog458's Avatar
dvldog458
Hey Guys!
I'm thinking it's time to do a gear swap. I've saved up enough money for the install, and I'm gonna bit the bullet.
What ratio would you recommend? I'm currently running stock 3.73's w/ a limited slip in the rear. I noticed a big difference when I upgraded to 40" tires. Now it's time to get back to the stock feeling.
Old Apr 18, 2014 | 09:27 PM
00X7.3PSD's Avatar
00X7.3PSD
4.71 to be proportional to stock 3.73 with 265/75r16 tires. Go with 4.88
Old Apr 18, 2014 | 09:45 PM
dvldog458's Avatar
dvldog458
Thanks!
I was thinking 4.88 or 5.13's just off the top of my head.
Old Apr 19, 2014 | 07:30 AM
1 Excursion camper's Avatar
1 Excursion camper
Well 4.88 would bring you back to stock, and with the diesel should be more than enough. if you had the V-10 then I would recommend the 5.13`s.
Old Apr 19, 2014 | 07:45 AM
hav24wheel's Avatar
hav24wheel
I'd say 4.88s. Or step up to 5.13s if you want a little more get up and go. It will nock the RPMs up a bit. But shouldn't be too much.
Old Apr 19, 2014 | 08:06 AM
acf6's Avatar
acf6
4.88s in a diesel? id go to like 4.30s max...
Old Apr 19, 2014 | 09:44 AM
AndrewCJohnston's Avatar
AndrewCJohnston
I'd first swap the Dana 50 for 60, then go for 5:13's. I swapped to the 60 and went 4:30's with 35" tires…I've got 250 or so more RPM's at 75 mph..which with 40's you can use the extra rpms to keep them rolling…a few more lbs of boost too to help keep the EGTs lower.
Old Apr 19, 2014 | 05:36 PM
1 Excursion camper
He's running 40" tires.
Old Apr 19, 2014 | 05:40 PM
acf6's Avatar
acf6
Yeah but its not a V10. Ive never heard of guys with diesels swapping much lower than 4.30s...i have 35s and 3.73s and its like perfect all around. Most people run 37s on 3.73s and have no issues
Old Apr 19, 2014 | 06:15 PM
fordboy2's Avatar
fordboy2
The 488 puts him back to equivelent to stock 373. I would do the 488s
Old Apr 19, 2014 | 07:48 PM
AndrewCJohnston
You guys ever drive a truck with 40s? They are all pigs. Go lower with 5:13s and u wont be disappointed.
Old Apr 19, 2014 | 08:26 PM
Stewart_H's Avatar
Stewart_H
That is close, but the 4.88's would push him to the high end of usable RPM's.
5.13's with 40" wheels would be too much for a daily driven 6.0L PSD, in my opinion.
A little higher than stock.
Based on what experience? Have you ever driven a 6.0L PSD on 40" tires and 5.13's?
Don't get me wrong, I'm not knocking you, just trying to get a feel for how much experience you have with that combo, or close to that combo, because your experience may be that you won't be disappointed, but it's been my experience that people with too tall of a gear (numerically speaking) and not enough tire to offset it, will be disappointed.
My fellow moderator Toreador Diesel followed peoples advice for R&P ratio and he regretted it because the gear was too much, even though everyone told him the gear ratio calculator said he would be spot-on equivalent with the stock ratio.
He had to do a second R&P gear swap (very expensive) because he went with the "general consensus."
Miles has the right idea. I have a 6" lift with 4.30's on 37" tires and I'm like 0.5 mph off on my speedo.
In my opinion, you would be very pleased with 4.56 gears. The 4.88's would be too much, in my opinion.
Stewart
Old Apr 19, 2014 | 08:31 PM
fordboy2's Avatar
fordboy2
I didn't think of the 4.56. I would agree thats probably the best option fein relation to getting back to a stock feel.
Old Apr 20, 2014 | 03:12 AM
dvldog458's Avatar
dvldog458
I like the 4.56 idea..... makes sense.
Thanks for all your input guys.
Old Apr 20, 2014 | 05:26 AM
00X7.3PSD's Avatar
00X7.3PSD
I think Tor's example was 4.30 gear for 35" tires. He overshot by ~4.88% going with 4.30 instead of 4.10. He should have gone with 4.10 in the first place.
This is because 37" tire calls for 4.36 ratio "mathematically." 4.3 is perfect.
4.36/4.3=1.01395 (~1.4% off)
1.01395x70mph= 70.977 (~0.98mph off)
He'll be happier with 4.71
Stewart
4.88 instead of 4.71 is ~3.61% off. (4.88/4.71=1.0361)
1.0361x70mph=72.53mph (~2.53mph off)
4.56 instead of 4.71 is ~3.33% off (4.71/4.56=1.0329)
1.0329x70mph=72.30mph (~2.3mph off)
OP's ratio of 4.71 is not available so either 4.56 or 4.88
4.56 if the truck is running around empty.
4.88 if the truck is going to tow heavy.
Also, going from stock tires to 35" isn't that big of a difference. Going from stock tires to 40" is a huge difference. Not only weight, but also width.With 4.88 gears, you overshoot ~3.61% which shouldn't be too bad when you factor in the big,wide and heavy tires into the equation. (I'm talking about towing)
