Sponsored by: Real Truck
5 star tuning
Old Apr 20, 2014 | 08:55 AM
  #31
MisterCMK's Avatar
MisterCMK
Originally Posted by NovaNewfie
What I have been told is that in tow/haul the truck does not use fourth.
4th is used in cold temps and some downshifts
Sent from my Telegraph using IB AutoGroup
Old Apr 20, 2014 | 09:09 AM
  #32
nojoke327's Avatar
nojoke327
I knew the 4th gear part. It usually shifts 1-2-3-5-6. There is definitely a difference between 4 and 5 gear but the whole, "it lets your truck use all its gears" is a little deceiving as far as advertising that for a tuner.
Old Apr 20, 2014 | 10:38 AM
  #33
Lubbockguy1979's Avatar
Lubbockguy1979
The 5r is actually a 6 speed tranny. It does only 5 of the 6 forward gears but it is based on a bunch of different things like tow haul mode, temprature demand etc.
Old Apr 20, 2014 | 10:45 AM
  #34
Lubbockguy1979
This is from one of bismic's very detailed posts reguarding the torqueshift.
Torqshift Gearing:
These are the numbers for an 05-07:
1st: 3.114 to 1
2nd: 2.218 to 1
3rd: 1.545 to 1
4th: 1.096 to 1
5th: 1 to 1
6th: 0.712 to 1
Rev: 2.88 to 1
These are for the 03-04:
1st: 3.09 to 1
2nd: 2.2 to 1
3rd: 1.583 to 1
4th: 1.096 to 1
5th: 1 to 1
6th: 0.712 to 1
Rev. 2.88 to 1
From Matt at Spartan:
1st Gear applies the Forward, Low-Reverse, and Coast Clutches.
2nd Gear applies the Forward, Low-Reverse, and Overdrive Clutches.
3rd Gear applies the Forward, Intermediate, and Coast Clutches.
4th Gear applies the Forward, Intermediate, and Overdrive Clutches.
5th Gear applies the Forward, Direct, and Coast Clutches.
6th Gear applies the Forward, Direct, and Overdrive Clutches.
Essentially, the transmission basically operates as a 3-speed transmission with a gearsplitter, (the splitter being the overdrive pack).
1st gear is Low; 2nd gear is Low-"Over".
3rd gear is Intermediate; 4th gear is Intermediate-"Over".
5th gear is Direct; 6th gear is Direct-"Over".
Primary shift strategy shifts in the following order: 1-2-3-5-6. 4th Gear is skipped.
The only conditions under which 4th gear is actually used is under certain specified tow-haul downshifts; and primarily, cold-shift strategy.
Cold shift strategy is as follows: 1-2-3-4
Cold shift strategy is only used when the transmission fluid temperature is below 5deg.F
Old Apr 20, 2014 | 10:04 PM
  #35
elroy0451's Avatar
elroy0451
4wd High
+ 1 on the SCT from Mike. It definitely woke up my 08 F350 6.8. The throttle response improvement alone is worth the money, but the transmission shift points are crisper and the engine is noticeably snappier. Money well spent.
Old Apr 21, 2014 | 07:46 AM
  #36
gddyup's Avatar
gddyup
Another really nice thing about the tuner. Gear shifts are greatly improved.
Richwon4
Jul 19, 2018 03:35 PM
Dave0629
All Things Towing
Oct 23, 2012 07:12 AM
RAGaz
Modular V10 (6.8l)
Nov 17, 2009 08:22 PM
TCamper
Mar 28, 2007 05:31 PM
mossygoose
Computer Chips & Tuners
Feb 9, 2005 09:39 AM
