5 star tuning
09 V10 which one of the tuners would you get? im not sure what the biggest differences are. do you need to plug each one in when you want to change the tune that you are using? mainly want to get one for towing 10k lb camper
You don't need a tuner on a 2009 V-10 to tow a 10k camper.
Tuners really don't do much for gas trucks in terms of power. The tow/haul mode should help, also rear end gearing will make more of a difference than tuning.
Ok. Thanks. I just got this truck and havent pulled the camper yet. Pullin it out of storage wednesday
The V10 is a serious pulling machine, the 10k should be no issue!
5 STAR TUNER WILL WAKE IT UP BIG TIME.
Originally Posted by rdinmv
(Post 14272281)
How so? The tuning on these trucks with the 05+ trucks is pretty aggressive compared to the 99-04 models. It's not a diesel and pulling 10k behind a 3V V10 is nothing. The last thing you want to do is start running tunes while dragging a trailer around. Nothing beats the factory tow haul mode setting. V10's produce their peak power at 4250 -4500 rpm. Running anything past that is a waste. How would a tuner help In terms of power on a gasser? On the pre 05 trucks it's a different story. |
throttle response will feel more like a cable not drive by wire, trans shifting strategy's are much better and quite a nice bump in hp and tq and tow haul works even better.
Do a search, it makes the truck feel like it dropped 2000 lbs, its the best mod you can make to a 3v v10 even the 87 octane tune. |
Originally Posted by Kdr358
(Post 14272298)
What kind of power? Any dyno sheets before and after to verify the huge power gains? The dyno would also give a better picture of where and how the power is increased
(Post 14272298)
Originally Posted by Lubbockguy1979
(Post 14273750)
Originally Posted by schrod
(Post 14273795)
I don't know about the 6.8 but I did have a 2010 F150 with the 5.4 and put a tuner on it and you could not believe the world of difference it makes! I not only got a lot more power but also increased my mileage by 2 to 3 mpg's. |
Originally Posted by pappy19
(Post 14273809)
You obviously haven't been on Mike's web site, the dyno results are all there. |
The tuner DEFINITELY wakes up the V10. I only run an 87 octane tow/perf tune and it is sweet. Anyone who says the tuner doesnt help the V10 is not familiar with a tuned V10. Specially one tuned by 5 Star. It will hurt MPG but adds a ton to the way the transmission shifts in or out of tow/haul. Definitely worth the $ if you want a great mod.
Ps you can ask the fellow in his 6.0 what he thinks of my tuned V10 from the other day. He looked surprised from what I could see in my mirror. |
