I suspect it won't. I think that a 98 used an external PATS module but the 99 moved to the newer system where the PATS is in the cluster and the PCM communicates with the cluster for that function rather than the external module.
I agree with projectSHO89 that it will likely not work. When it comes to the computers, you only want to swap them when the numbers on both computers match.
