Help with Distributor.
Old Apr 17, 2014 | 11:44 AM
Oxfordrider's Avatar
Oxfordrider
I finally found a 1995 351 Windsor roller. To make things easy I am just going to swap the intake, carb and whatever I can off of the the 1975 351 W that is currently in my 54. Does anyone have recomendations regarding a new distributor or a new timing gear I can use on my existing distributor. Any other advice will be appreciated. Thanks.
Old Apr 17, 2014 | 12:27 PM
old_dan's Avatar
old_dan
So...just to clarify....you're taking off all of the fuel injection system and going to make it a carbureted engine?
I did the same with an 89. It will probably be necessary to get timing gears for the camshaft for an early 351w so that your valve timing will be straight up.
If you leave the stock roller cam in there, you'll need to use a distributor gear that is the same material as the gear on the stock HEI distributor. One of our members (Paul aka Imsoquazy) went through having a bronze distributor gear disintegrate after a couple hundred miles.
Dan
Old Apr 17, 2014 | 12:30 PM
ungerp's Avatar
ungerp
I have had nothing but excellent luck with MSD products. I have Pro billet 8350's on both my 351C and 429. While a bit pricey I would recommend the 8354 for your 351W and if you are running a roller cam, change the cam gear to the bronze since I have been told roller cams are hard on the normal gear and can cause problems.
Old Apr 17, 2014 | 12:31 PM
52 Merc's Avatar
52 Merc
Yes, you need a steel distributor gear to match the roller cam. I'm not 100% positive, but you could probably take the gear off the efi dizzy and use it on your original dizzy and be fine. Lots of places will have the correct gear for your application, too, if you can tell them what you're doing and what you need.
see next to last paragraph...
http://www.carcraft.com/techarticles/distributor_gears/
Old Apr 17, 2014 | 02:29 PM
Oxfordrider
To answer a few questions. I am going with a carb and mechanical fuel pump. I understand that I need a steel or composite distributer gear. Anything else I should be aware of?
Old Apr 17, 2014 | 04:37 PM
ALBUQ F-1's Avatar
ALBUQ F-1
A '75 engine would have a really smog-friendly timing curve in the dizzy and carb. That was about the low point of carbureted engines. I'd guess the vacuum advance both advances and retards the timing? An earlier or aftermarket dizzy like the MSD would really kick it up a notch.
Old Apr 17, 2014 | 05:28 PM
Oxfordrider
I currently have the stock distributor updated with a Petronix.
Old Jul 8, 2014 | 09:41 AM
Frank Racing's Avatar
Frank Racing
Distributor recommendation
I would like to know if you guys have an experience with one of those D.U.I. performance distributors, i'm working with a 1974 351M engine with hydraulic roller cam for my 1968 F100 pick up truck, this is my first time building an engine and a person recommend me this distributor.
Old Jul 8, 2014 | 12:41 PM
dmack91's Avatar
dmack91
I can't help on the DUI, but I did use a TSP HEI on my 289 and am happy with it. Single wire hook-up sealed the deal for me (and $38 shipped at the time). Keep in mind if you go with an HEI that it is a large cap (I had to space my air cleaner up an inch to clear).
Old Jul 9, 2014 | 09:18 AM
Frank Racing
Thank you for the advice, first the price of the TSP is a lot better, somebody recommend me Bronze gear hope this guys from TSP offer that option.
Old Jul 9, 2014 | 09:39 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Before springing for the TSP chinese part, check to see if it uses standard OEM cap and rotor, advance springs, etc. and whether the internals (electronics) are available as spares. The big advantage of MSD and retrofitted OEM distributors is that spares are readily available and reasonable.
Old Jul 9, 2014 | 12:40 PM
old_dan's Avatar
old_dan
Frank,
I'm pretty sure that you don't want that bronze gear. I'm not entirely sure which one you want but I do know that a bronze gear can disintegrate over time if it is matched to a camshaft with a hardened steal gear. The key is to go with whatever the camshaft manufacturer recommends. In your case, the ticket would be to find out what the gear material is for the stock HEI distributor. Either use that gear, or one made of the same material.
I think you'll be very happy with that 351w with a carb on it. Mine is from an 89 F150 and is working out well. The 89 is a flat tappet engine, but it's working for me!!
Dan
Old Jul 10, 2014 | 10:53 PM
Frank Racing
Thank You Dan,
Just FYI I have called comp cams, first technician recommend me melonized gear, and another one sent me an email and recommend me bronze, and the guys from the distributor company told me to use the standard gear but they will contact comp cams and take the final decision.
Now I need to get the flywheel, headers and transmission, probably the tranny just one from the junk yard just to start the engine 351 M,
restoringmy46
Nov 28, 2011 10:15 PM
Raxid
Engine Swaps
Nov 7, 2008 01:59 PM
pc_2000
Jun 12, 2008 02:45 PM
1982fordf100
May 10, 2006 09:09 AM
lmadore
Oct 25, 2005 07:53 AM
