92 4.9 wont start
Old Apr 17, 2014 | 12:15 AM
VR6Nutt's Avatar
VR6Nutt
92 4.9 wont start
I posted this in the older F150 section also.
I am normally in the 7.3 or Excursion area, but my kid got a new-to-him 92 F150 with the 4.9L inline 6. The PO(s) really did a number on this poor truck - many loose nuts/bolts from drive shaft to body mounts. Anyhow, the kids been driving the truck for the past week without any issue until today. Came home complaining about high idle. I did some searching and found that this is a common issue and proceeded to check the obvious first being vacuum lines, TPS, IAC. In doing the testing, the starter failed. Removed the starter to find that the solenoid came loose from the starter body. More loose bolts, I know. Fixed that and tried to restart - no go. More digging revealed an improvised wire wrapped around one of the fuel lines in the rear of the motor. It connects to a harness wire red/white stripe. The other end is a mystery. Could it be this wire is preventing engine from firing? Tested 5.1V with key on. Please see pic and let me know if it looks familiar to any of you. As I am currently stuck on where this wire goes and what to check next...
Old Apr 17, 2014 | 02:16 AM
timbersteel's Avatar
timbersteel
I think that is coolant temp sender wire for the gauge in the dash. It looks very similar to my '92, 4.9, and 302.
Old Apr 17, 2014 | 11:10 AM
VR6Nutt's Avatar
VR6Nutt
That would explain why the temp gauge doesn't work. Any idea where the sender is?
Really strange thing is the truck started this morning after it wouldn't fire yesterday. Now the CEL is on so I have something to go off of.
Old Apr 23, 2014 | 06:50 AM
Crock Pot's Avatar
Crock Pot
The sender is hard to see, but you can feel it. It is on the top end, near the back on the left side. The intake makes it hard to see from up top. I could see it from underneath when I changed the O2 sensor, but not reach it. Once you figure it out, it isn't hard to change in the blind.
Old Apr 23, 2014 | 12:53 PM
VR6Nutt's Avatar
VR6Nutt
Yeah I got it sorted. It was the sender - and was easier to access from underneath. I shortened up the wire and voila! Gauge works again. Also the reason it didnt start was the TPS. Unplugged and it fired. Changed it out - now runs much better.
Mcrncic
Jun 15, 2017 04:32 PM
Argess
Oct 16, 2016 04:15 PM
ModernLife
Jul 19, 2015 07:19 AM
VR6Nutt
Apr 17, 2014 11:13 AM
Beast12
42
May 17, 2004 02:58 PM
