Brake boosters for my 56 F250 and 50 F5 Dump truck
I have been searching for some time now for the proper brake boosters for my two trucks. A 1956 F250 and 1950 F5 Dump truck. I have read alot of posts and searched vendors information but I am not that confident in making a choice of what to purchase. I am more interested in installing a frame mounted type. Possibly with a remote resevoir. Both trucks are stock drums front and rear. Can anyone help with info on what has worked well to make this upgrade?
Only help i have is, having a friend or know a friend that has a friend at NAPA to scroll through their brake book or computer. A frame mount 10 inch Bendex is what you need. I got one for my F6 there new for around $180.
May have to drill a hole or two for a bracket. You don't need a reservoir either. lmportant to use a hard line like
3/8 copper tubing and short hose connections for vac supply and a one way valve mounted on the fire wall.
your 50 F5 should have a booster from the factory I don't know about the F250 maybe a dealer installation..
Just don't fall into their trap when they say what year make and model. These guys today are keyboard parts
people they have no clue that a booster is a booster used by all makes, my front end loader has a booster exactly the same as my F6.. problem is now a days they threw all the books out and when they started that I always asked give books to me. So I you do get stuck I have the master Napa brake books they gave me with hundred of pictures dimensions or you could google Bendex Brake boosters on line....sam
Stephen67,
What I would like to do is improve my brakes safety by having a boosted dual circuit system. Both trucks are currently in the stock configuration. Drums front and rear. The F5 is a COE with the239 flathead engine and the F 250 has a 215 6 cylinder. I appreciate the robustness of a hydraulic boosted application. I believe I could install a hyd. pump of the the 6 cyl. without to much anguish. The COE may be more challenging because of required space. Both trucks have adequate brake systems now. I would like to be safer on the road with more modern components.
Regards
Regards
Christopher Workman
04-08-2019 07:45 PM
NapaRick
04-08-2014 11:55 PM
John & Old Ford
15
11-18-2012 06:46 PM
Dustin_86
04-24-2006 09:22 AM
T-Bone_600
10-27-2004 08:04 AM
