Need a Holley 847 Carb
Old 03-17-2011, 06:34 PM
CrazyDog66's Avatar
CrazyDog66
CrazyDog66 is offline
I've got my 49 F1 226 I6 to start, but my carb is junk. It has a crack by the boss for the choke linkage and leaks bad, I have been searching for one but can't find one.
Can I convert it to a 2bbl? Or maybe some one has one laying around they would part with.
Thanks
Randy
Old 03-17-2011, 07:14 PM
59JEEPSTANG's Avatar
59JEEPSTANG
59JEEPSTANG is offline
I believe ArmyFord had a post that showed a salvage yard with some older Fords, they may have one. He is from the Colorado Springs area so you might try PM ing him for some information. Here is one of his threads showing a couple pictures of the yard.
https://www.ford-trucks.com/forums/1...o-a-48-f3.html
Paul
Old 03-17-2011, 07:48 PM
CrazyDog66's Avatar
CrazyDog66
Thanks 79JeepStang
I'll try Army and see what happens.
I see in your profile that you have a 66 Stang also.
I'm almost finished with the resto of my 66, this year will be the 40th anniversary of my ownership. The past 5 years I finally had the funds and time to get her back on the road, basically I have to do the interior and then it's cruise time.
Old 03-17-2011, 11:17 PM
tinman52's Avatar
tinman52
tinman52 is offline
Welder User
I checked my stash, but I don't have an extra.....But I discovered awhile back that the carb for a 215-223 six (52-64) will work on the 226 motor. They are a Holley 1904...new ones are still available....
Old 03-18-2011, 08:41 PM
59JEEPSTANG
Crazydog, glad to hear your Mustang is nearing completion. I totally restored mine about 10 yrs ago (it was originally going to be a parts car). I love driving it, just don't do it enough. That is quite something owning it for 40 yrs, my father has had his for 35 now. I can remember going with my brother looking for a Mustang back in 73, he looked at a 66 289 convertible for 800 dollars. Did not buy it because the battery was dead..... ended up with a 68. Anyway I bet if you could find a Autolite 1100 (off 6 cyl Ford early to mid 60's) it would work, it seems to fit the 215.
Paul
Old 03-18-2011, 10:49 PM
lvin4jc's Avatar
lvin4jc
lvin4jc is offline
When I was looking for a carb for the 226 all the manuals I ran across called for a 7HA or 7HT carburetor?
Old 03-19-2011, 12:21 AM
51PanelMan's Avatar
51PanelMan
51PanelMan is offline
Where are you finding new 1904s? I'm curious, because when I needed two for my 215, I had to get them rebuilt.
Old 03-19-2011, 05:54 PM
tinman52's Avatar
tinman52
tinman52 is offline
Welder User
Rock Auto has them. I shouldn't have said NEW....they are remanufactured.
$118 +core. Look up '56 Ford F100 w/223...
I am going to try one on my '62 I think...all of the ones I have, the fuel bowls are warped and they leak.
Edit, these don't have the glass bowls, but look the same otherwise
Old 03-19-2011, 07:04 PM
CrazyDog66's Avatar
CrazyDog66
Thanks TinMan,
I'll give them a try
Old 03-19-2011, 10:54 PM
ArmyFord's Avatar
ArmyFord
ArmyFord is offline
Crazydog66,
If you are interested, the junkyard is Webb junkyard just east of the Springs on Hwy 94 in ellicot. They have a few flathead eights and sixes in the yard.
Dan
Old 03-19-2011, 10:55 PM
ArmyFord's Avatar
ArmyFord
ArmyFord is offline
Crazydog66,
Dan
Old 03-22-2011, 10:33 AM
1952's Avatar
1952
1952 is offline
Email sent.
Old 03-22-2011, 04:40 PM
CrazyDog66's Avatar
CrazyDog66
Hey 1952,
I don't have email privleges yet, not enough posts.But.....
The flange bolt center is 2 3/4"
Throat diameter 1 9/16"
Thanks
Randy
Old 03-23-2011, 02:29 AM
1952's Avatar
1952
1952 is offline
I'll check tomorrow.
Old 03-23-2011, 03:53 PM
1952's Avatar
1952
1952 is offline
3" flange, won't work. It does have an 1-9/16" throat, though.
Quick Reply: Need a Holley 847 Carb
