2011 6.7
Old Apr 16, 2014 | 09:37 AM
R.K.ONeilJr's Avatar
R.K.ONeilJr
Hello the fire,
is the 2011 6.7 a reliable motor? I heard a rumor that hey had a valve problem?
Many Thanks
R.K.
Old Apr 16, 2014 | 02:51 PM
BCM's Avatar
BCM
30K miles on mine, split between city driving and hauling a 15K fifth wheel... No problems yet. But I also maintain it meticulously and by the book.
Old Apr 16, 2014 | 03:07 PM
ruschejj's Avatar
ruschejj
The early trucks built in 2010 did have exhaust valve issues. Mine lasted 121,000 before it blew.
Otherwise, everything is pretty good.
Old Apr 16, 2014 | 03:19 PM
Randy_270's Avatar
Randy_270
I have seen reports of early built trucks running 200k miles or more with out problems. Some have the valve problem and some don't, any truck made before March 2011 has the highest chance of dropping a valve though. I have even seen a truck with 500k miles and the only problem the owner said it had was the heated seats quit working. Another large issue with these trucks is the turbo. Mines been running 32+ psi of boost for 32k miles so far but its starting to make not happy sounds .
Old Apr 16, 2014 | 07:13 PM
brmccolley's Avatar
brmccolley
Owned since April 2010- no issues
I use my 2011 King Ranch truck primarily for driving between Washington DC and central Michigan, 700 miles each way, and I haven't had any problems with my truck. However, I left my truck pretty much stock and I drive my truck rather sedately. I have put a Titan 50 gallon tank on my truck to enhance range but otherwise I've left the fuel and engine system intact. I never know what to think about the issues I read about on these forums, I can only attest that I haven't had any issues.
Old Apr 20, 2014 | 09:30 AM
cabindoc's Avatar
cabindoc
70,000 miles on my early build (job 1) 2011 and no major problems. I think if you work it to it's max capability ever day, your going to be more likely to break something. If you drive it as a DD and occasionally max it, you should be okay.
I have a friend who has a 2010 Dodge Cummings, which most think are bullet proof. He doesn't tow a lot, but he removed EGR and DPF stuff, put a tuner on it and at under 80,k miles, he blew a head gasket.
ATP Pilot
6.2L V8
Nov 12, 2017 10:26 AM
EXv10
Feb 20, 2014 05:49 AM
Oshow
Jan 11, 2013 11:01 PM
FARM69
Apr 20, 2009 10:02 AM
07 F250 Aggie Mobile
Nov 6, 2008 12:09 PM
