I am considering buying a 1994-2002 f250 or f350 w/7.3 power stroke.
I have heard the automatics have issues. What should I keep my eye out for?
This is all new to me since all my vehicles are 32+ years old and manual.
Thanks for any info.
Like any automatic transmission they require proper routine maintenance in order to live a long full life. The E4OD and 4R100 are rugged transmissions but they fail prey to poor maintenance and high operating temperatures. If the previous owners skimped on maintenance then you may end up with a very expensive repair bill.
Depending on how deep your pockets are too you can always send it out to (insert shop name here) in California. They are known for beefing/upgrading auto transmissions for diesels if you aren't going to convert it to a manual.
The 2001 4R100s used a mechanical diode that liked to fail. '95-'97 E4ODs are the better units, with '97 being the best. I believe the 4R100s progessively got better, save for the 2001 transmissions.
The biggest problem with the E4OD is the lack of an adequate cooling system. It employs a very small oil/air heat exchanger that really isn't even suited well enough for the power steering. Ford also installed 5/16" cooler lines which are entirely too small.
Upgrade the anti-drainback valve, cooler lines and fittings to 3/8" and install a tru-cool MAX heat exchanger and temps become more manageable.
There is also much to be said about the E4OD's lock-up programming which leaves much room for improvement. Some say it stays unlocked for too long, making power into heat that the stock cooling system cannot manage. Add to that, a converter that is constructed more for a much weaker gasoline engine, and you have a time-delay grenade.
Thanks again guy's.
I would prefer a manual tranny but my wife wants an auto so she don't need me to haul her horse.
All the info makes me feel a little better knowing the issues can be resolved.
I've got my eye on a 97 extra cab long bed with 116xxx miles on it for $6650.00. Nice looking truck that's been well taken care of.
I had thought about upgrading my lines. If I decide to do that, I'll have them custom made by a shop here in town. The offer a few choices when it comes to lines and I'd like to get something flexible if I can. With the steel lines on there now that have no insulation, I'd think they have a slight cooling effect while the fluid is going to and from the trans. That being said, any suggestions on what type of flexible line would cool enough?
Also, what is a good, typical operating temp range for the E4OD? In the past I had a temp gauge on mine but have since taken it off. IIRC, the temps were ~220F...not sure though, it's been a while.
