SCT tuner after engine work w\ no studs
Old Apr 15, 2014 | 01:45 AM
rattleNsmoke's Avatar
rattleNsmoke
I had quite a bit of top-end work done including an EGR delete and MBRP 4" turbo back kitty-delete exhaust system. I picked up an SCT 3015 tuner to shut off the 'check engine' light. My question is, without head studs what SCT canned tune is relatively safe for every day street driving and what is good for heavy towing? I pull a 14k fifth wheel during the summer and would like to be safe, yet have a little more low and mid range grunt. I have ScanGauge, so I'm watching my boost when accelerating. I do not want to lift my heads. On this board some guys mention custom tunes written by several techs. Which is recommended and what would ya'll use if this were your ride? Thanks in advance, Mike
Old Apr 15, 2014 | 08:43 AM
mustang_309's Avatar
mustang_309
I use the canned SCT 65hp tow tune without studs and no problems, you need to monitor EGT's if you are going to tune it and keep the EGT's under 1300*
Old Apr 15, 2014 | 01:48 PM
SuperStrokin''s Avatar
SuperStrokin'
I have stock bolts, I have egr delete, no cats or mufflers into dual 5" stacks, afe intake, and an sct sf3 on whatever the top setting is, and mine runs fine. also got an atlas 40 ficm on the way from ficmrepair, so hopefully she will still hold up until i get the time to do the studs.
Old Apr 15, 2014 | 02:33 PM
King-bRanch's Avatar
King-bRanch
Wifey with a ton of patience
Awesome me too
I dont have a SCT but I do run an Edge CS Programmer along with a full MBRP 4" Dual Exhaust (no kitty), S&B Cold-Air Box, Banks High-Ram Intake & the Blue-Spring Upgrade all the time on the 60 hp Tow Tune with Stock Head-Bolts for 2.5 years now w/NO issues & I pull a 31' 5th-Wheel
P.S...My Boost doesn't appear to go over 28/29 lbs & ive read the Stock TTY's can stretch @ 32 lbs
Old Apr 15, 2014 | 09:24 PM
rattleNsmoke
Thanks for the reply's! As much fun as I imagine it would be to romp the hell outa the truck, I can't afford to grenade this thing.
Mike
Poorboy04
Jul 15, 2014 08:53 PM
add2255
Jun 18, 2011 12:03 AM
G.Landry
Sep 30, 2009 12:52 PM
Chris89lx
Apr 28, 2009 11:41 AM
Tim Hartman
Nov 14, 2005 11:28 AM
