2.9 flywheel/starter grind
Old Apr 14, 2014 | 09:35 AM
kshell52's Avatar
kshell52
Cool 2.9 flywheel/starter grind
Ok so first off, I drive a 1987 Ford Ranger 4x4 2.9L 5speed, around 5 months ago it made a grind noise, so I installed a new flywheel, clutch, pressure plate, throwout bearing (pilot bearing), and starter. Well around 5 days ago the grinding started again and now its to the point where it will not start. What could be causing this? Starter bench tests perfectly and looks good, used flashlight to look at flywheel while having somebody manually turn the crank, it all looks good.
Old Apr 14, 2014 | 10:14 AM
f5fordgirl's Avatar
f5fordgirl
The clutch in the starter bendix may be bad.
Old Apr 14, 2014 | 10:16 AM
Old93junk's Avatar
Old93junk
The starters on 2.9s "back off" note how the upper mount hole is ovaled, loosen it, use a pry bar and drive it inboard toward the flywheel as far as it will go, re-tighten.
Seems peculiar to the 2.9, my 2.8 has never had this problem.
kshell52's Avatar
kshell52
doubt it
I just put another starter on over the weekend due to the lifetime warranty, still grind w/no start.
Old Apr 14, 2014 | 10:19 AM
kshell52's Avatar
kshell52
thanks, I'll try this when i get home today. Being 17 and only in auto tech program i dont know much about older vehicles. Thankfully im starting UTI July 28th.
Rustlin'
Nov 3, 2014 10:24 AM
70T351W
Feb 4, 2008 05:37 PM
Power Strokeme
31
Jan 26, 2008 07:21 PM
sadbroncowner
Bronco II
Dec 20, 2005 10:50 AM
Indy63F100
May 9, 2005 08:42 PM
