Coolant Block Plug STRIPPED !!!!!!!
Old Apr 13, 2014 | 09:00 PM
8lug's Avatar
8lug
Anyone ever try to remove the block plug and strip the 8mm hex head !! As if there is not enough to go through trying to service these trucks this sh## has to happen !!!! And lets just put another plug right behind the starter wow what an engineering break thru !!!! Not sure how I'm going to get this out and install the Fumoto valves ? Any ideas out there ??
Old Apr 13, 2014 | 09:34 PM
jswartz84's Avatar
jswartz84
PB blaster, and give it a couple firm smacks with a hammer and chisel.
Old Apr 13, 2014 | 09:35 PM
Headviking's Avatar
Headviking
Use Easy out. Nut extractor.
http://www.ebay.com/itm/Craftsman-13-Pc-Damaged-Nut-bolt-Extractor-Set-/261451016955?pt=US_Hand_Tools&hash=item3cdfb1eafb
Old Apr 13, 2014 | 09:36 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
leave the passenger side one in and only use the driver's side. works the same, might take one more flush
Old Apr 14, 2014 | 06:26 AM
donf610's Avatar
donf610
I did the same thing. Use a torx, fits better..T 50 or 45 i forget. When I bought replacement plug it was designed for a torx
Old Apr 14, 2014 | 06:43 PM
8lug's Avatar
8lug
Okay **** one of these suggestions will work I'm sure with a few ####. Thanks to all.
Old Apr 14, 2014 | 06:51 PM
69cj's Avatar
69cj
I'll give you a couple more tips. Calm down s**t happens. When you put the new plug back in, use wrist pressure. The O ring seals not the threads. A litle anti-sieze also won't hurt anything.
fyrehose
Aug 20, 2014 11:55 PM
KayJay11
Oct 17, 2010 01:19 PM
robjs111
Sep 10, 2010 01:21 AM
Diesel Fiend
Jan 21, 2007 12:57 AM
84whitef250
Apr 27, 2004 04:57 PM
