Testing Alt Amp output?
Old Apr 13, 2014 | 08:48 PM
xaviar's Avatar
xaviar
In short. Battery light came on a few weeks ago. Scangaugell was reading 11.2, 11.6 then 12.5 and the light went out. Did this a few days and replaced the alternator with the 140 upgrade with the 58mm pulley.
No more red battery light and scangauge11 reads 14.2, 14.1 until about 5 or 10 minutes of driving. Then it stays around 13.5-13.8. Just curious to know what my actual amp output is at idle without accessories running and with them on. I'm thinking I could use my Fluke meter to see actual amp output.
Thanks in advance.
Eddy
Old Apr 13, 2014 | 10:18 PM
BLADE35's Avatar
BLADE35
yes if your fluke has the inductive amp clamp
But Guessing your truck should be around 80-90amps at Idle HOT
Cold start usually peaks at 230-240amp Breifly
Its time for me to buy one
Old Apr 13, 2014 | 10:22 PM
78fordman's Avatar
78fordman
Not all flukes will read dc amps. My 373 wont. Check the meter 1st. It will still read something but it won't be right.
Old Apr 13, 2014 | 10:29 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Hot idle amps with no accessories is about 50 amps.
Josh
Old Apr 14, 2014 | 07:50 AM
69cj's Avatar
69cj
Thanks in advance.
Eddy
Too me it sounds like your good to go. The alt. should only put out what the batterys need or you overheat them.
Old Apr 14, 2014 | 07:59 AM
Bullitt390's Avatar
Bullitt390
Seeing 13.5-13.8 at the OBD port is roughly 13.7-13.9 to 14-14.2 volts at the battery as well
Josh
Old Apr 14, 2014 | 11:31 AM
xaviar's Avatar
xaviar
Thx all for the advice. I didnt think my fluke 75 would read amp output. Sounds like I'm good to go as it seems.
Josh, I did pick up that smaller pulley off eBay. Great deal too. Thanks for the tip. Put it on last weekend. If I new what I know now I would have gotten the 94-97, 3G large case 130 amp alternator instead with 3g to 6g pigtail. That's a better alternator and puts out more amps at idle than the large case 6g. ill run this one till it craps out and switch to the 3g.
Thanks all.
Eddy
Old Apr 14, 2014 | 06:40 PM
Jmoen7's Avatar
Jmoen7
Sorry to thread jack, i'm guessing i have a stock alternator because at idle my alternator doesn't like to charge. At high idle it will, and high way driving around 13.5-14 it's jumpy.
Was stock likely to not charge at idle? i always have issues with my batteries getting low so i keep it on a maintainer to save my FICM as much as possible
Old Apr 14, 2014 | 07:04 PM
69cj's Avatar
69cj
Not enough info. How do you use the truck? If they're short trips you'll never compensate for the glow plugs. You need to supply more info.
Old Apr 14, 2014 | 07:18 PM
BLADE35's Avatar
BLADE35
So turning my truck on and off 5 times in the drive thru does that count Mike LOL
Old Apr 14, 2014 | 07:21 PM
BLADE35's Avatar
BLADE35
Josh
Guess the vid I saw was Cut short
Old Apr 14, 2014 | 07:29 PM
69cj's Avatar
69cj
And then you drive 5 miles home to feed the kids? Or drink your beer, LOL. Sure death to something in the system. JMHO. People, no offense, don't realize these are not the every day gassers or last decade diesels.
Old Apr 14, 2014 | 07:50 PM
Rusty Axlerod's Avatar
Rusty Axlerod
You can also check alt output with one of these. The load adapter in the foreground is kinda cool. Put it on the battery and connect the cable to the other end, crank with the buss bar in place (to check alt), disconnect buss bar with the thumb screws and the scale reads up to 90amps with the resistor that's on there now, or you can put a different one on and read to 180 amps.
It also works on the new GM HEI ignition systems!
I've had this thing for years and it still works. Bought it from Sears in the late 70's and it broke the bank at the time lol. The instruction manual has pictures of cars from the 60's and even discusses testing generators. I think it was old when it was new!
Old Apr 14, 2014 | 08:31 PM
Bullitt390's Avatar
Bullitt390
Mustang_309 has a good YouTube clip showing alternator amp output at cold start and when the GP cycle off.
Josh
Old Apr 14, 2014 | 09:33 PM
BLADE35's Avatar
BLADE35
I think the video I saw moere focused on how High it went they could have everything on to IDK
Video main point was peak amp at startup
