6CYL AC Brackets
Old Jul 4, 2003 | 08:18 AM
tbeachaz's Avatar
tbeachaz
6CYL AC Brackets
Need help locating brackets,pulley andbelt tensioner for my 68 F100 300CI 6 CYL I will be using a york compresser.
Old Jul 4, 2003 | 08:00 PM
mantta's Avatar
mantta
6CYL AC Brackets
About the only place you are going to find them is a salvage yard. I went through the same thing with my 71 F-100 some years ago.
Old Jul 5, 2003 | 01:16 PM
Nod's Avatar
Nod
6CYL AC Brackets
Tbeachaz,try oldairproducts.com,they provided an AC bracket for my 71 inline six when I bought the whole AC kit.My bracket was for a Sanden AC Pump but they might sell one for a York as well it's worth a try anyway.Or mabey You could use a Sanden compressor for your setup?Good Luck!
"bowties in the rearview mirror"
Old Jul 9, 2003 | 11:15 AM
Red/White and Ford's Avatar
Red/White and Ford
6CYL AC Brackets
The question I have is are you going to stay with R-12 or convert to 134a? If you are converting, the right compressor would be with a rotary compressor like Sanden. The other advantage to using the rotary compressor is that is uses less horsepower to run since the engine is moving 7 small pistons in series rather than one very large one. ackits.com sell both the mount and drive along with a rotary compressor. If you live in an area of high heat, I would also suggest changing the condenser from a tube and fin to a paralell flow.
Old Jul 11, 2003 | 09:41 AM
tbeachaz's Avatar
tbeachaz
Wink 6CYL AC Brackets
Thanks for all of your input
Old Jul 11, 2003 | 09:51 AM
steve83's Avatar
steve83
6CYL AC Brackets
Like this?
Old Jul 11, 2003 | 03:52 PM
tbeachaz's Avatar
tbeachaz
6CYL AC Brackets
Yes just like that!
Old Jul 11, 2003 | 06:19 PM
tbeachaz's Avatar
tbeachaz
6CYL AC Brackets
After looking carefully at your picture, it appears that this is a York mounted on a V6 engine. What I want to do is put my York Compressor on an in line 6 Cyl. But thanks anyway.
Old Jul 13, 2003 | 04:53 PM
steve83's Avatar
steve83
6CYL AC Brackets
I'd have sworn on my deathbed that it was a 300, but now that I look again, I think it's a 302.
Sorry about that... :blush:
Old Jul 13, 2003 | 07:04 PM
tbeachaz's Avatar
tbeachaz
6CYL AC Brackets
No prob guess ill go with AC kits they have a bracket and compressor,thanks for trying anyway
scottness2
May 27, 2014 06:10 PM
maverick600
WTB - Parts & other
Dec 10, 2013 03:56 PM
bailegb
WTB - Parts & other
Jul 11, 2010 08:53 AM
kidder31264
Jan 21, 2006 02:12 AM
darkman
Oct 22, 2002 07:26 PM
