I burnt a grill up , so to speak , using a chemical remover in the past . I tried oven cleaner with no great effect. Other than taking it to be tanked ,is there another way you guys are doing it without spending 8 hrs. a day for 2 months to wet sand it ?
Tanking is the best way to get it done. Sanding can lead to thin spots and sore everything. Oven cleaner will only work on small spots and leaves discoloring.
You'll come out ahead to have it tank stripped and re-anodized at the same time.
I will look for another place to tank it. I dont like the company I have used before . I won't have it reanodized but I will polish it then use some of Eastwood's clear over it. I was hoping there was another way.
I made my own "tank" Made a box from 2x6s and laid 6mil plastic in it as a liner. Filled with HOT water then put a WHOLE box of powder draino in. Put the grill in it and let is sol for 5 min and pulled out to check. Used some 400 grill sand paper to scrub the hard spots. IIRC it took about 30 min total
Thanks y'all for your input. I will try the yellow top easy off. If that don't work I will try the remover on page 43 of Eastwood's spring catalog.
Wet sand blemishes , polish with wenol or simichrome , then clear or not clear . Haven't decided yet .
I am not, but the shop that is close to me, is not , to put it nicely , on my Christmas list. They have lost and ruined parts of mine in the past . I don't like them nor trust them.
So if I can do it myself and get the results I want , I will .
