Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
1995 F800 ignition Security
Old Apr 11, 2014 | 01:17 PM
Skyline Drive's Avatar
Skyline Drive
I'm having some problem with employee(s) making copy of my truck keys. I've replaced the ig. cylinder but that doesn't help. Apparently when on the road the driver can stop in any key shop and have one made. I'm looking for a way to stop this but have come up empty in my searches. Has any one run into this problem?
Old Apr 11, 2014 | 01:29 PM
85e150's Avatar
85e150
Google "do not duplicate key law" and learn that stamping your keys with that is pretty much worthless.
Why are they making duplicates? Is there any legit reason?
How much of a stink do you want to make?
You can put a policy in writing and have them sign and keep a copy, stating that duplicating or have a duplicate key is against policy and can/will result in termination. You have to create a paper trail and be reasonable about it.
You should consult an HR or employment lawyer if you are not comfortable doing the above.
After that, then you have to make a couple high profile examples out of folks who won't comply.
Generally, people who violate one rule or request are not shy about violating another. They guy who repeatedly makes dupes is probably also cheating on hours or speeding or giving rides to hookers.
No simple solution. However, unemployment is high, and those who don't play by the rules must be made to feel that their employment security is low.
jmo, no part of this is real legal advice, ymmv, prices higher in Alaska and Hawaii.
Old Apr 11, 2014 | 06:37 PM
80broncoman's Avatar
80broncoman
You always arrive before all employees correct?
If so you could hide extra switch that shuts off the Electric Fuel pump Or the Ignition, OR Both.
But this requires you or someone you REALLY trust to stay late or arrive early.
80broncoman
Old Apr 12, 2014 | 06:27 AM
Skyline Drive
Both your ideas are good but not fool proof. I was thinking about a replacement ig. switch and that the key could not be copied at a local key shop. The only way to make a copy is to go back to the vendor.
I would like to find a vendor who can provide this service.
Old Apr 13, 2014 | 11:47 PM
85e150's Avatar
85e150
Good luck with that. google it as I suggested and find out more....
DieselCamper
Aug 26, 2016 10:21 PM
chewedtoothpick
Apr 23, 2013 07:27 PM
TJS96F-150
16
Jan 1, 2008 04:49 PM
desertdave35
1978 - 1996 Big Bronco
Feb 14, 2007 11:37 AM
