From time to time my radio decides to display everything it can at one time..
Sometimes it will clear itself other times I have to turn off and on the radio to clear it..
Has anyone seen this before? I don't plan on changing the HU anytime soon, but want to make sure its not signs of other issues to come when I do replace.
Were you adjusting the climate control before all this happened? The screen is in a test mode. You enter it by pressing the two left-most buttons (power and defrost I think?) simultaneously. A few presses of the power button will exit out.
this happens from time to time without actually doing anything, sometimes it happens when I start the truck.. sometimes im just driving and glance over and see it like this..
So the power button you are referring to is the temp power? or radio power?
Usually I don't turn on or off my temp, I leave it set so when I get it in and start its already set.
