Brake help
Old Apr 10, 2014 | 10:19 PM
Alpha Lima Romeo's Avatar
Alpha Lima Romeo
Brake help
Hi guys
So i finally got my truck out of the garage and now everything is going good except one big thing. The brakes are no good. Seeing as i don't know much about brakes i figured I'd see if anyone has suggestions. I have a 1991 F-250 with a 5.8 and RABS. The only brake work i have done was i bled them a few weeks ago. Before they were soft with a squishy pedal. I made sure the reservoir never got to low and didn't push the pedal down to far. But now i have decently firm pedal and no stopping power. I can hold the pedal half way down and put it in reverse and it still moves. The pedal doesn't slowly fall nor can you pump them back up. I was thinking at first maybe the master cylinder. Could this be a symptom of air in the RABS module and if so is 1991 after they made them to were you had to use the code to activate it for bleeding? I haven't pulled the wheels for leak check/pad inspection but my fluid level is the same and there's no visible leaks.Thanks in advance
Old Apr 11, 2014 | 06:43 AM
Bob Gervais's Avatar
Bob Gervais
The first step you should take, since it sounds like you successfully bled the brakes, is to check the pads/rotors and drums/shoes. Since you have a firm pedal, my guess would be that the rear drum brakes are either worn or out of adjustment.
carchub
May 15, 2015 12:30 PM
WBBulldogs
1997 - 2003 F150
Jan 27, 2013 11:35 PM
jxer00
Jun 10, 2007 04:52 AM
Thomas A
Oct 25, 2005 03:42 PM
Rmcmorris
Aug 25, 2004 11:51 PM
