Engine
Old Jul 7, 2003 | 05:40 PM
  #31
77'F-150Mudder's Avatar
77'F-150Mudder
Engine
The first guy I talked to wasn't sure so he double checked availabilty. He said they sell a brand I'd never heard of. I got to thinking about my question about different owners so I called a different NAPA which I know is owned by a different guy and they also said Jaspers weren't available. They mentioned yet another brand I hadn't heard of. This leads me to believe that individual store owners do indeed source from different places. So that being said, I don't doubt that a particular NAPA in MT would sell Jaspers where, on the other hand, noone around here in ID does.
I wish I could find a local distributor. I'd like to get a quote besides the Jasper website.
Old Jul 7, 2003 | 07:14 PM
  #32
OnyxtygerIV's Avatar
OnyxtygerIV
Engine
So if I got a 400 I could still use my edelbrock intake?
Oh ! and get one "WITH" smog tubes?
Old Jul 7, 2003 | 10:03 PM
  #33
Matts72's Avatar
Matts72
Engine
I don't know Scott. My neighbor doesn't get home from work until later but I will ask him agian.
Onyxtyger-- the 351 and 400 engines are basically identical the only difference is the crankshaft and pistons. You can interchange any parts between the two, except for maybe a cam, the 400 makes better torque and HP so you don't need such an aggressive cam, it will still fit just won't work as well.
Instead of posting a bunch of times before anybody answers you, you can click the 'edit' button, you have 60 minutes to edit a post. good luck
Old Jul 7, 2003 | 10:32 PM
  #34
OnyxtygerIV
Engine
Sorry for all the posts its just that i'm not use to getting so much help.Anyway, it's good that 351m and 400 r interchangable,now I can go ahead and bump up the power.Thx a bunch guys.
So I can just interchange all my external parts to the 400, hmmmmm starting to sound very manly. Hehehehe.
Old Jul 7, 2003 | 11:01 PM
  #35
Mil1ion's Avatar
Mil1ion
Engine
Did someone say they wanted more power AR AR AR AR !
from a 400 ?
Read us !
http://www.off-road.com/ford/flashback/400_power.html
http://home.earthlink.net/~bubbaf250/index.html
Old Jul 7, 2003 | 11:20 PM
  #36
77'F-150Mudder
Engine
400 Cleveland???? That's funny... At least he knows the difference if you read through it.
Old Jul 8, 2003 | 12:22 AM
  #37
OnyxtygerIV
Engine
Who said anything about a 400 C?
Old Jul 8, 2003 | 12:37 AM
  #38
77'F-150Mudder
Engine
In the first link Million gave the guy has "Engine Tech: Power Secrets of the 400C Revealed!" at the top of the page. I just thought it was funny. Die hard Cleveland guys (I'm just a semi-die-hard Cleveland guy) would scoff and probably take offense to that statement. If you read through the page you'll learn a few of the fundamental differences between the 351C and the 351M/400. They may seem minor but OH what a difference.
Old Jul 8, 2003 | 12:38 AM
  #39
Mil1ion's Avatar
Mil1ion
Engine
The Ford 400 is known as a Cleveland because that's where they cast them.
http://www.oemfordparts.com/faq/smal...v8.htm#351M%20(MOUNTED)%20AND%20400
Old Jul 8, 2003 | 01:00 AM
  #40
77'F-150Mudder
Engine
Mounted, Modified, (what was the other one?). When will anyone have a difinitive answer to what the M stands for?
I will digress a little bit. The books I have refer to 351C, 351M, and leave no designation behind the 400. Logic would dictate that since the 351M and 400 share the same deck height, journal size, and everything else aside from stroke and rods the 400 should be designated a M. But since when has Ford ever been logical? Perhaps it's bacause there aren't 3 different 400s to designate like the 351. They were all produced in Cleveland weren't they (except the Windsor)? I don't know, that's why I ask. I don't see where on that page where the 400 is referred to as a C.
Sorry, I didn't mean to sidetrack the original topic of sourcing a good remaned. engine.
Old Jul 8, 2003 | 03:59 PM
  #41
OnyxtygerIV
Engine
As I said I was just worried about the Edelbrock Intake fitting a 400 other than that everything else will be replaced.
Now anyone know where I can get a decent pair of headers and duel exhaust kits?
What are the 3/4" and 1/2" holes on the front of the intake for?I've never seen the Original intake so I have no idea what devices are supposed to go there.Check out what I'm Talking abot plz.
http://img.villagephotos.com/p/2003-7/268662/2171.gif
Old Jul 8, 2003 | 04:23 PM
  #42
Matts72's Avatar
Matts72
Engine
That would be for the Thermactor setup, and maybe for an EGR passage.
Old Jul 8, 2003 | 04:43 PM
  #43
Torque1st's Avatar
Torque1st
Posting Legend
Engine
The hole on the upper left of the pic is for the thermactor air injection. The hole below and to the right of it is on the intake runner and is for vacuum accy hookup. There is a matching vac port hole on the upper right hand side.
Old Jul 8, 2003 | 08:55 PM
  #44
OnyxtygerIV
Engine
So I can block off the 3/4" hole since I'm not using any egr or thermactor systems. And the previous owner had the distributor hosed to the 1/2" hole via hose adapter. Is this correct?Or should I hook the vaccuum advance to the holley carburetor?
By the way on an important note this is the best forum on automotive mateers I've ever been to thanx to all for putting up with my questions.
Old Jul 9, 2003 | 02:51 AM
  #45
Matts72's Avatar
Matts72
Engine
Your questions are why most of us are here.
You can block it off unless you find something that needs that Vacuum. Mine goes to a charcoal box.
