Sponsored by: Real Truck
How to remove spark plug wire bolt?
Old Apr 10, 2014 | 02:17 PM
birddseedd's Avatar
birddseedd
Went to change the plugs on an 02 f350, the bolt holding the plug wire boot on doesnt seem to fit any standard size socket. 7 is too big, 6 is too small. 1/4 is too small, 9/32 is too big.
thanks for the help
Old Apr 10, 2014 | 02:38 PM
DavidB's Avatar
DavidB
I am not positive that it is the same on all year models and all engines, but on a 2000 6.8 v10, the bolt head is 7mm.
A 6 point socket works best for me.
Old Apr 10, 2014 | 02:39 PM
nojoke327's Avatar
nojoke327
I had a similar issue yesterday. I believe 6 or 7mm fit but it was tight on several due to rust buildup. I would gently tap it on with a hammer and clean them up before you reinstall
Old Apr 10, 2014 | 02:51 PM
birddseedd's Avatar
birddseedd
i tried taking a wire brush to it
Old Apr 10, 2014 | 03:16 PM
acf6's Avatar
acf6
I believe it is 7mm
Old Apr 10, 2014 | 03:19 PM
birddseedd's Avatar
birddseedd
Originally Posted by acf6
I believe it is 7mm
7 has quite a bit of play tho. looks like it woudl just strip it. im a bit affraid to turn it.
should i soak the plugs in oil over night? in case they are the original crappy ones that break. iv been told to do it engine warm, and engine cold. which?
thanks
Old Apr 10, 2014 | 03:22 PM
Charlie5280's Avatar
Charlie5280
PB blast....soak those babies and allow it to de-oxide some of the Iron Oxide on the bolt.
Old Apr 10, 2014 | 03:39 PM
birddseedd's Avatar
birddseedd
what do i do about not having a socket that fits it?
Old Apr 10, 2014 | 05:35 PM
redford's Avatar
redford
FTE Leadership Emeritus
Go to Harbor Freight or Northern Tools, or Sears.........and buy a socket that fits.
Old Apr 10, 2014 | 06:00 PM
birddseedd's Avatar
birddseedd
I don't think its a standard size. its inbetween 6mm and 7mm.
Old Apr 10, 2014 | 06:11 PM
redford's Avatar
redford
I thought they were 8mm? Anyway, they are a standard metric size.
Old Apr 10, 2014 | 06:13 PM
birddseedd's Avatar
birddseedd
For the life of me i cant get 6mm on them, and 7 has a lot of wiggle room. enough i know its gonna strip it. i just know it.
Old Apr 10, 2014 | 06:31 PM
jetjockey99's Avatar
jetjockey99
I don't have one so I can't say, but if a 6mm is too small and 7mm is too big try a 1/4" 6 point, it is equal to 6.35 mm. it may work.
Old Apr 10, 2014 | 06:54 PM
ot106's Avatar
ot106
Change plugs on an aluminum head engine with the cold. This reduces any risk of any slightly seized aluminum (to plug threads) being removed with the plug.
Old Apr 10, 2014 | 07:01 PM
Tom's Avatar
Tom
The factory size is 7mm, so unless someone has put some funky aftermarket bolts that's what you have. Make sure to use a 6-point socket. These bolts don't have much torque at all, you shouldn't strip them.
