D44 Front Axle question
Old Apr 10, 2014 | 03:17 AM
SuperDuty93's Avatar
SuperDuty93
Ok so my highboy has a 78 d44 HP front axle with the dual piston calipers. I come outside today to see that my pass front tire has oil drips on it...
The axle tube end is leaking on the bottom right behind the knuckle... I also noticed the knuckles both can be moved horizontally like 1/4-3/8 of an inch. Is that normal? And im trying to figure out why it just randomly started leaking (and it seems like its leaked a lot) because I haven't used the 4x4 almost ever.... I currently don't even have a front driveshaft on the truck.lol
I assume there is a seal there and its a pain to get to.. Anyone have a suggested diagram or link to the best descriptive way to take the pass side apart and fix the leak?
Thanks
Old Apr 10, 2014 | 07:20 AM
NW 150's Avatar
NW 150
If your knuckles move in any direction than left and right for turning purposes, I'd assume that the ball joints need replaced. You may have a bad axle seal as well causing your leak but that's just my guess.
green_95
Jun 6, 2016 09:28 PM
mark996
Jan 25, 2014 11:46 AM
fordsrawesome
Nov 17, 2012 11:02 PM
sand_fiend
Oct 27, 2010 07:50 PM
mexicoF250
Apr 11, 2010 04:44 PM
