tire clearance
Old Apr 8, 2014 | 04:49 PM
Mr.Shellback 65's Avatar
Mr.Shellback 65
tire clearance
I have a 2003 F 250 super duty reg cab 4wd 5.4 gas 6 speed stick with snow plow package option/higher arch springs from factory .Its stock and sits high like the early 99's. I was thinking of putting 38 / 15.50 SSR's swampers on it .Has any one on here got them to clear with only 3 body lift and bush w. cutout fender flares ,No suspension lift? trying to keep the C O G down .Currently have 255/80/17(33.3 inch) km2 bf good's with approx. 3 inch clearance when turning. also would ad 4.88 gears, ox in the front, arb rear.
thanks M K
Old Apr 14, 2014 | 01:34 PM
jesse5's Avatar
jesse5
No, too wide for the leaf spring clearance even if you used the 13" width at that height. Charts call for 8" lift.
The unit bearings would not last long either.
Old Apr 14, 2014 | 05:01 PM
Mr.Shellback 65
38's
ok thanks I was planning on custom wheels from Marsh wheels 16.5x12 with a major negative offset. As far inward as possible .
79F250isalive!
Jul 17, 2014 09:29 PM
bleeding blue
Dec 27, 2009 11:33 AM
Customz
Dec 26, 2004 09:29 PM
sneakypete
Jan 26, 2004 09:41 PM
natewoz
Offroad & 4x4
Aug 5, 2003 03:14 PM
