back spacing
My experience, on an '83 stepside, which may, or may not be that much different than yours, using Hoosier Pro Street 31x12.50x15's and 10" Cragar Soft 8's (4" backspace), the tires stuck out about 2" past the wheelwells. So, we ran it up on the lift, did some measuring down under there and determined that we could use 2" more backspace and still clear the springs, etc... I got Cragar involved and found out they can make me Soft 8's in the backspace I needed, then went through Summit to order. In my case, they cost about $20-25 more than the standard ones, each.
The wheels will be custom, and you'll probably have to contact Cragar to see just how much backspacing (they insist on calling it 'rear' space) you can get out of the wheels you want to use. Some of their wheels can be made with more backspace than others; for instance, I have Cragar S/S's on my '76, and will be installing the same, or larger, Hoosiers on it, so I figured I'd get S/S's with 6" backspace, but they can't make the S/S in 6" backspace.
