So I have an 88 f150 standard cab long bed auto 5.0l engine which im taking the motor out of and putting in my other car. I want to swap it to 5 speed or 4 speed manual. So I know I need a flywheel and clutch and starter. I want to know what vehicles and what years 2wd trannys will bolt up to the 5.0l motor?
Also does anyone know a good company that will help me get a driveshaft made or modified to go from a ford tranny to a Nissan rearend?
You are putting a 5.0 into a Nissan. OK, car or truck? Intended use? If you are drag racing it's one thing. Using it as a truck would be another, and as a daily driver another.
As for the drive shaft, you will have to have one made, and you should search out a drive line company near you. Expect $200+ depending on what else you have to buy in addition to a new tube.
