Gauges not working?
Old Apr 7, 2014 | 12:09 PM
dresden78's Avatar
dresden78
Question Gauges not working?
The fuel gauge in my 78 f250 custom does not want to work and the speedometer only works after driving a few miles. there was mice in the truck after sitting over time. could this just be a wiring problem?
Old Apr 7, 2014 | 12:16 PM
dresden78's Avatar
dresden78
also all of the lights and other electronics work (ie. turn signals, break lights, dash lights, etc.)
Old Apr 7, 2014 | 12:19 PM
FordFanboy's Avatar
FordFanboy
Fuel gauge is on empty or full? Or something else?
Old Apr 7, 2014 | 12:22 PM
dresden78's Avatar
dresden78
stuck on empty even though the tank has about 10gal in a 19gal tank
Old Apr 7, 2014 | 01:48 PM
fmc400's Avatar
fmc400
MSEE
Disconnect the bullet connector near the tank that leads to the sending unit pigtail. Short the female terminal inside the TRUCK-side connector to the bolt where the pigtail grounds with a jumper wire. Turn the key to accessory, and the gauge should peg FULL. Report your results.
Old Apr 10, 2014 | 10:30 AM
dresden78's Avatar
dresden78
i will attempt this method over the weekend thank you for the tip
lawdogg_78
Oct 9, 2011 12:02 PM
zhilton
May 28, 2011 02:31 AM
fordguy712
Nov 5, 2008 07:49 AM
MustangGT221
Jul 16, 2006 05:49 AM
Stoner150
1997 - 2003 F150
Jan 10, 2004 11:32 PM
