Flushing
Old Apr 7, 2014 | 10:59 AM
KDAVID1's Avatar
KDAVID1
Flushing
I may have missed this in the tech folders but when you are changing an oil cooler and doing a coolant flush--do you do the flush before the new cooler or after? Also how "dangerous" is it to flush the system if not changing components or doing a backflush?
Old Apr 7, 2014 | 11:36 AM
KIDkiser's Avatar
KIDkiser
If the temp spread is out of whack,do a vc9 and restore flush BEFORE you change coolers.if everything is ok,and you just want to change coolant just do a distilled flush with no chemicals.
Old Apr 7, 2014 | 11:55 AM
KDAVID1's Avatar
KDAVID1
If you are changing from Ford Gold to Cat can you just do the distilled flush?
Old Apr 7, 2014 | 12:17 PM
KIDkiser's Avatar
KIDkiser
Yup,just make sure you get all the gold out.
Old Apr 7, 2014 | 06:22 PM
wildcat421's Avatar
wildcat421
I plan to do this this weekend also. My temps are great so I plan to just do a flush and replace with cat coolant. My question is should I do a couple flushes with tap water to get all the gold coolant out? And then do 3 flushes with distilled water? I do plan to remove the thermostat for all the flushes. And is it best to remove the block plugs during each flush? I also have the sinister coolant filter to install before the last fill with cat coolant.
f150crewcab
Mar 29, 2015 11:48 AM
pickle40
Feb 7, 2015 08:19 PM
f350project
Sep 3, 2014 08:06 PM
Joseph Bravo
Jul 8, 2013 08:30 AM
Restlesswildman
Mar 17, 2013 06:12 PM
