pls help lightning engine rebuilt
Old Apr 6, 2014 | 04:20 PM
payanhilario's Avatar
payanhilario
I have a 1993 lightning and I was changing the water pump and with my luck the bolts snap off inside the block well it made me mad ended up breaking the timing cover now I want to rebuilt the engine with stock everything just new piston rings and all of the gaskets any idea where I can find a good one at a decent price?me and a friend are doing all the work
Old Apr 6, 2014 | 10:22 PM
baddad457's Avatar
baddad457
Try Summit racing for overhaul kits. Next time you attempt to remove a SBF waterpump, use heat and a gentle amount or torque to get those bolts out. It can be done without snapping those bolts off. And use thread sealer on those four bolts (two per side, top and bottom of the port holes) I use ordinary pipe thread paste for this, you can also apply antiseize to the bolt shanks to keep them from corroding to the aluminum, you probably won't need that as the pipe dope will keep the coolant from seeping past the threads.
fabieber
Mar 16, 2014 10:20 PM
jemini
Mar 15, 2012 07:34 PM
azcobra
Modular V8 (4.6L, 5.4L)
Oct 2, 2011 09:30 AM
burley68
1983 - 2012 Ranger & B-Series
Oct 25, 2009 02:50 PM
Dannym
Dec 17, 2004 07:25 AM
