Modular V10 (6.8l)
Spark Plug Torque Spec, please
Old Apr 6, 2014 | 05:23 AM
Winnie32v's Avatar
Winnie32v
2000 F-53 Chassis, Triton V-10, 6.8L. Built up to a Winnebago Class A.
What is the torque spec for the spark plugs?
Also, my book calls for spark plug # AWSF-22E.
I'm told that I won't have a problem removing them from the Aluminum head. I'm looking forward to this going smoothly.
Is there an upgrade from Ford OR can you recommend a replacement plug?
I've heard of Autolite as being OK.
Also, does anyone know the Ignition Coil # for this unit? AND where to get a set of 10 at a reasonable cost?
Thanks
Old Apr 6, 2014 | 07:06 AM
projectSHO89's Avatar
projectSHO89
Autolites are okay. The Motorcraft SP479 is the recommended replacement.
I use 28 ft-lb.
Probably a DG508 or DG511, you can look it up. You can buy anything from aftermarket to Motorcraft coils for your engine from Rock Auto. The MC coils will run around $40 each. Inexpensive ones will run $15 or less. You can buy Chinese coils off eBay for under $10 each. Most people who know how to troubleshoot simply replace the coil boots and plugs for a tuneup, then replace any individual coils as they might fail.
Old Apr 6, 2014 | 03:34 PM
Wolfboro's Avatar
Wolfboro
You should be using Motocraft SP479 as recommended by the previous post .
As far as the torque , it is a controversial subject . Ford Motor Company 2000 Shop Manual recommends spark plug torque 15 Nm ( 11 lb-ft ) .
Project SHO89 says he torqued his 2001 Super duty to 28 lb-ft without any issues .
By the way I torqued my 2003 12 lb-ft (with anti-sieze) about less than 5 K miles ago, (too early to make a comment on mine ) . So, you will have to make a choice of torque based on your personal preference .
Just remember that your motorhome engine block may only have 4 threads that will hold the spark plug.
I would also suggest to replace your COP coils as needed , there are reports of original Motocraft COPs lasting 200+K miles . If I have to replace mine , it will be either Motocraft or its maker Standard brand .
Good luck and happy trails,
Old Apr 7, 2014 | 05:56 AM
JWA's Avatar
JWA
This is probably one of the most controversial topics about a Modular Motor, V8 or V10.
For interesting reading try this link: https://www.ford-trucks.com/forums/1...ead-heads.html
What I do on my own E250's is use nothing but MC plugs, thin coat of nickel-based anti-seize and carefully run my torque to 23 ft/lbs. First click of the torque wrench and I stop pulling. So far over three different Modular Motors this has worked perfectly, never had a plug loosen on me.
xtal_01
Apr 29, 2016 10:57 AM
live2hunt
Modular V10 (6.8l)
Feb 27, 2013 06:54 AM
brian Felts
Modular V10 (6.8l)
Jun 24, 2009 07:01 PM
paul
Modular V10 (6.8l)
16
Apr 2, 2008 07:49 AM
PTMR2
1997 - 2003 F150
Dec 26, 2006 10:20 PM
