Strange charging problem
Old Apr 5, 2014 | 08:57 PM
gjpond's Avatar
gjpond
Helloo everyone, I have a 65 f250 with 352. It charges at 11.9 to 12 volts at idle and when I turn blower motor on the charging rate is erratic at 15.5 to 16 volts. I have never heard of anything like that before, could it be a bad ground? The firewall is pretty rusty and the ground cable looks to have seen better days.
Old Apr 6, 2014 | 06:39 AM
Franklin2's Avatar
Franklin2
Check the ground at the regulator. It grounds through the regulator housing. If you have to, but a ring connector under one of the bolts and run a ground wire to somewhere else if the mounting spot for the regulator is too rusty. You should also have a ground from the engine block to the firewall. If it cranks over ok, your large battery ground is probably good.
Old Apr 6, 2014 | 06:04 PM
gjpond's Avatar
gjpond
Thank you, I`ll look into it one of these days.
Markwillett
Sep 3, 2016 12:08 PM
Victor L
Dec 21, 2010 08:31 PM
james G. phillips
Jul 17, 2008 05:16 PM
60RatRod
May 15, 2008 05:07 AM
chicowoodhill
Dec 5, 2006 11:40 AM
