Fuel pressure problems
Old Apr 4, 2014 | 10:16 PM
Saltlife01's Avatar
Saltlife01
I have a 89 f150, which I'm not getting any fuel to the motor, it turn over but the the motor doesn't fire. I had a bad DFR which I bypass with the fuel lines and I'm still not getting any pressure to the motor. I think it's the fuel pressure regulator and it's been giving me fits, can anyone help me plz
Old Apr 4, 2014 | 10:26 PM
RIKIL's Avatar
RIKIL
Remove the vacuum line from the FPR. Do you smell or see gas in the vacuum line? With the line off, try to start the motor. What happens?
Old Apr 4, 2014 | 10:32 PM
timbersteel's Avatar
timbersteel
Need to isolate either low psi in tank pump or high psi side frame pump as culprit.
I'm leaning towards low psi in tank pump.
Others will chime in...
Old Apr 5, 2014 | 08:01 AM
subford's Avatar
subford
Do you hear the high pressure fuel pump and the selected in-tank fuel pump run for one second each time you turn on the key?
Old Apr 5, 2014 | 11:21 AM
Saltlife01's Avatar
Saltlife01
I took off the line off of the FPR turn the key on and gas came out of the line. The pump kicks on I cranked and it turned over for a split sec, but still no motor fire
Old Apr 5, 2014 | 11:55 AM
timbersteel
Looks as if the FPR has failed. If you removed the vacuum line from the FPR and fuel poured out, I'm thinking that it has failed. That may be why it won't start if fuel psi is so high, its flooding the engine. That would allow raw fuel to be sucked into the intake.
If you pull the plugs, are they soaked with fuel?
Old Apr 5, 2014 | 12:01 PM
subford's Avatar
subford
Yes you have a bad Fuel Pressure Regulator (FPR).
Replace the FPR.
Then start it by holding the throttle wide open until it starts and as soon as it starts shut it off and change the motor oil.
Old Apr 5, 2014 | 12:05 PM
timbersteel
X2 on changing the oil after the repair.
Old Apr 5, 2014 | 01:13 PM
Saltlife01's Avatar
Saltlife01
Thanks I give it a shot
1320stang
Aug 15, 2018 02:07 PM
tsalley55
Aug 25, 2015 08:03 AM
deltajuke
Jan 11, 2013 01:08 PM
dakota-boy
19
Feb 18, 2012 10:18 PM
ziller
Jun 9, 2006 07:08 AM
