97 F250 7.3 PSD with E4OD
My truck is currently 2wd and i want to convert it to 4x4, using a solid axle.
My question is this, does anyone have a parts list or website that lists interchangeable parts? I want to keep it an automatic as my knees are shot.
I recently replaced the E4OD (ouch) and would like to keep it.
In order to use your trans, you'll need to change the output shaft and the tail housing. A front shackle reversal kit is an easy way to get a front spring mount. The rest is pretty much bolting on the stock 4x parts. The 350 in my sig was 2x when I bought it.
