Sponsored by: Real Truck
Load Rated Tire Recommendations
Old Apr 6, 2014 | 12:24 AM
Chriso83's Avatar
Chriso83
Originally Posted by senix
Get the truck on the scales and quite guessing.
go to your local truck stop that has a cat scale. They will give you steer, drive and total weight.
do it empty and then do it with the trailer. That is about the only way to know where you stand.
For SRW on the side wall multiply by two what ever the max load at 80 psi is.
Changing tires to a different size or manufacture may increase what the tire can carry.
Here are my weights from an earlier trip.
I have been and will be heavier (have had rear axel to 6250lbs).
UNLOADED
Front Axel 4660 lbs
Rear Axel 3120 lbs
Truck curb wt. 7780
LOADED
Front axel 4850 lbs
Rear axel 6100 lbs
Trailer Wt hitched 9750 lbs
Trailer only 12200 lbs
Pin Wt. 2450 lbs
Truck Wt 8500 lbs
Truck Wt w/ trailer 10950 lbs
GCVW: 20700 lbs
Tires rated max load 3195lb ea
Wheels rated max load 3195 ea
CO
Old Apr 6, 2014 | 06:35 AM
senix's Avatar
senix
Page 32 of this document has the specs.
File Type: pdf
Old Apr 6, 2014 | 08:09 AM
FordmanNJ's Avatar
FordmanNJ
Originally Posted by Chriso83
What tires did you go with at that size?
Did you also get a spare in the same size?
If so, do you have any issues mounting the larger spare tire?
I was hoping to stay with a 17" wheel so I would not have to get a spare tire on a larger wheel.
C
I wound up going with a set of Cooper Discoverer AT3s. I had a set years ago on another vehicle and they seemed to be a pretty good tire. So far with my F250 they have been pretty good with traction in rain and mud that I have encountered. I was looking at a few different tires like the Toyos/ Nittos line ups. I was close to pulling the trigger on a set of 35s from Toyo. Price was not really a factor since I was ready to spend that kind of money. However, the coopers had a pretty sweet deal attached to them which made them better choice at the time. (Really good price with rebate and 0% on the Ford charge for a bunch of months vs 1400 up front was a no brainer for taking 2 less inches in my book.)
No. The spare tire is the same as what the truck came with. LT265/70R17 BFG AT.
See answer above.
Word of advice. I looked at trying to keep the stock rims and go with larger tires. Many of the larger sizes wanted a larger rim to mount on. This would mean to keep the 17s I would have need to go to 17x9 rims to make larger rubber work. Since getting new rims for around 800-1000 was going to cut into the tire budget, I lucked out and found a set of take offs local to the area. Since they were OEM, I knew they were going to rated for load. I could get the tires for them if I were somewhere not close to home. I should have access to a "common size" within a day. Quite frankly, I am very happy with the decision I made when it came to my rubber and rims.
Good luck.
07EXPYEL
35
Oct 19, 2020 08:37 AM
jonrjen
All Things Towing
Jul 13, 2017 01:43 PM
PSP5980
All Things Towing
13
Sep 17, 2008 03:27 PM
Ultraute
Sep 9, 2004 08:30 AM
Bolliger
Jan 23, 2004 04:15 PM
