IH Water pump
Old May 23, 2014 | 11:58 AM
cowmilker08's Avatar
cowmilker08
Adding this thread to my favorites for when the day comes.
Alex, your machining looks good. And now we can get a pretty good guess at what injectors you want, lol.
Old May 23, 2014 | 10:09 PM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
Oooo. I've always loved that body style. Ever since I was a kid. My dad had a 79 f-250 camper special w/ a 400 and a 4 spd. Absolutely love them
Old May 27, 2014 | 12:10 PM
Awitte58's Avatar
Awitte58
Hah thanks Phil! Yeah I want Gretchen to break 600 hp someday..
And x2 Nick! I think it was 73-79 F100 and F150 were similar body styles. All that changed was the grill/headlight configurations. I want one, but that one was not nearly as 'clean' as the guy made it sound.
The 'slight rust in the bed' should have been 'the bed skin is practically gone is most areas' lol
Old May 27, 2014 | 12:17 PM
Awitte58's Avatar
Awitte58
Also question for you guys.
Would you use any special kind of paint? It is a water pump so I figure it won't see any high temps that require high temp paint.
Would you just use regular rustoleum primer/paint?
The shop back home that could match ford blue paint code is back home and I want this done soon so I might just pick up primer/paint that is close to Ford blue as I can find.
Old May 27, 2014 | 12:38 PM
cowmilker08
Rustoleum Black is what I would do.
Old May 27, 2014 | 03:22 PM
427 fordman's Avatar
427 fordman
Alex, I would think you can buy ford blue high temp engine paint at any parts store. I get it at my local hardware store.
Old May 27, 2014 | 03:53 PM
strokin'_tatsch's Avatar
strokin'_tatsch
Use the $2300 on injectors... Spend that kind of money to end up with a 351M? Eww!!
Old May 27, 2014 | 06:42 PM
Awitte58's Avatar
Awitte58
I ended up grabbin some grey primer and this OEM farm equipment paint.
Darin do you think the high temp is really necessary? I am about to put my second coat of primer on and then was going to paint, but if you think I should get high temp maybe ill hold off.
And don't worry Travis I passed on it. I am basically looking for a truck to take the 7.3 I am putting together. lol
Old May 27, 2014 | 06:43 PM
Awitte58's Avatar
Awitte58
Old May 27, 2014 | 07:29 PM
427 fordman
The water pump will have 200+ degree water in it, I'm not sure how much heat that paint will take.
Old May 27, 2014 | 07:33 PM
ReBilld's Avatar
ReBilld
X2 on the heat. I would use high temp on it. And good to see you on here Darin!
Old May 27, 2014 | 07:40 PM
427 fordman
Good to see you too Bill!
Old May 27, 2014 | 08:46 PM
  #28
strokin'_tatsch
I would like to think that stuff will hold up, but who knows. We painted the engine on my dad's old John Deere Model A with the same kind of paint, just in John Deere green and it is still holding up decently. I'm not sure how hot that engine is getting though. It does spin less than 1000 RPMs afterall. LOL
Old May 27, 2014 | 08:59 PM
  #29
madMatador78's Avatar
madMatador78
Lookin good Alex! Remember if you need a hand, I'm not far away!
Old May 27, 2014 | 10:29 PM
  #30
oldbird1965's Avatar
oldbird1965
That Ford gray paint I used was rated at 500°.
