Hub O Ring Seal
Old Apr 3, 2014 | 05:30 PM
hotrod351's Avatar
hotrod351
Hub O Ring Seal
ok my front manual hubs have been leaking for quite a while. for the life of me i cant find the orings anywhere, that is without paying $25.00 for a kit, which is stupid seeing as all i need are the two orings. 1990 f150
Old Apr 3, 2014 | 06:55 PM
GoinBoarding's Avatar
GoinBoarding
I had the same trouble. Removed hubs, put a bead of silicone around the lip of the hub, let it dry, reinstalled hubs. No more grease leaking out/water leaking in and since I had the silicone in the tool box already it cost me nothing.
Old Apr 3, 2014 | 07:46 PM
MeanGreen460's Avatar
MeanGreen460
I'll 2nd that on using silicone been doing that for yrs.
Old Apr 3, 2014 | 07:56 PM
eakermeld's Avatar
eakermeld
A tractor dealer or heavy truck parts place should be able to size one up for a few bucks.
Old Apr 3, 2014 | 08:03 PM
JWC 3's Avatar
JWC 3
I have a local hardware store with a Huge assortment of o Rings . I use them often , they are only a mile from my shop . Try an old school hardware store ... Just a thought !
Old Apr 4, 2014 | 03:58 AM
hotrod351's Avatar
hotrod351
have thought about the silicone
Old Apr 4, 2014 | 12:28 PM
hotrod351's Avatar
hotrod351
well what i found is that the hub bolts to a gear inside that has a big C-clip. that C-clip can move slightly forward and backwards. i guess after time of doing that it would cause it to leak. both sides do it.
KraigS
Sep 30, 2008 11:31 AM
kameronth
1978 - 1996 Big Bronco
Aug 31, 2007 09:27 AM
hedhntr
Oct 4, 2006 07:58 AM
