Front Diff oil change F250
Old Jul 3, 2003 | 01:51 PM
dcolvey's Avatar
dcolvey
I have a 1991 F250 4X4 8600 GVW and want to change the front differential oil. Is there a drain bolt or do I have to suck the oil out with a pump???
Old Jul 3, 2003 | 03:25 PM
c_rossman's Avatar
c_rossman
You have to suck the oil out. There was an artical on here where you can drill and tap for a drain plug on the bottom of the pumpkin. I would drive the truck around with the hubs locked in for awhile and then suck as much as you can. Water is heavier than oil and will sit on the bottom. Stir it up as much as you can.
jadmt
Mar 9, 2026 01:46 PM
jopiel
Feb 17, 2008 05:43 AM
Peter Richards
Jun 16, 2007 09:50 PM
78oldsmokey
Mar 16, 2006 09:23 PM
tangcoral2004
Sep 8, 2004 02:03 PM
