Help identifying rear differential
Old Apr 2, 2014 | 02:10 PM
85AustinTucker's Avatar
85AustinTucker
It's an 85 F150 4x4 with an IL 6 with 3 speed auto. Thinking about replacing fluids in both rear and front. Not sure where to start.
Old Apr 2, 2014 | 03:02 PM
RlCHARD CRANlUM's Avatar
RlCHARD CRANlUM
It should be a Ford 9 inch, a Ford 8.8, or possible a Dana 60-2. I don't know if they put a Dana 60-2 under a half ton in the 80's. I know they did in the 60's.
The 9 inch looks like this...
The 8.8 looks like this..,.
The Dana 60 looks like this...
If there are other options, or God forbid I'm wrong, I'm sure someone will be along shortly to point that out.
Old Apr 2, 2014 | 03:45 PM
85AustinTucker
Thanks Richard. I will do a visual this evening.
Old Apr 2, 2014 | 04:53 PM
bruno2's Avatar
bruno2
The front is a D44 TTB. You need to figure out if they are limited slip or not because the LS diffs take a friction modifier. Without it the clutches will burn up and frag the entire rear end.
Old Apr 2, 2014 | 04:59 PM
bruno2's Avatar
bruno2
You need to look for a tag hanging on the bolts of the cover. If it still has it on there post up the numbers and letters.
Old Apr 2, 2014 | 05:08 PM
Franklin2's Avatar
Franklin2
Never heard that and never had it happen. Most of these limited slips by now are wore out anyway and don't do much.
Old Apr 2, 2014 | 05:25 PM
bruno2's Avatar
bruno2
It happened to the rear end in my Dodge 1/2 ton. The clutches and steels went to pieces, then through the R&P as well as the pinions.Just the parts were over $500 to rebuild it. If my buddy wasn't a well seasoned rear end guy the bill would have been close to $1200.
This is from experience not just something I heard on the net.
Old Apr 2, 2014 | 05:27 PM
bruno2's Avatar
bruno2
Just running straight gear oil and not the stuff specified for LS or adding the friction modifier is bad news.
Old Apr 2, 2014 | 06:07 PM
85AustinTucker
Tag on the cover of the front or rear??
Old Apr 2, 2014 | 07:08 PM
85AustinTucker
Here are the numbers that I can read off the tag on the rear diff.
Top row. BDR And then AN21
Bottom row. 5588 S 808A
I think some of the numbers/letters are missing from the top row but that is all that is legible.
Old Apr 2, 2014 | 07:12 PM
Rogue_Wulff's Avatar
Rogue_Wulff
Bottom row, there's a "3" missing from the beginning, but it's a 3.55 ratio 8.8.
If you look closely, near the bolt head, you'll see the missing 3. That's not important. There *could* be an "L" between the 3 and 55. That would indicate a LS axle. Just a blank space (it's really a ".") would indicate a non-LS axle.
Old Apr 2, 2014 | 07:20 PM
85AustinTucker
What would LS or non LS mean for the potential difference in gear fluid needed? Do I need to crawl back under there and take a better look?
Old Apr 2, 2014 | 07:35 PM
RL250's Avatar
RL250
Yeah, time to crawl back down there. The LS is more expensive to fix, so make sure you are giving it the right gear oil.
KsCop's Avatar
KsCop
Limited Slip (LS) need gear oil with a friction modifier. You can by oil like that, or just get the additive
Old Apr 2, 2014 | 09:03 PM
cbr600f31997's Avatar
cbr600f31997
There should be a code on the door that will tell you what rear you have and if its ls.
