Stupid stupidness......
Here is the what's wrong list:
1. AC compressor seized (and it's about to get hot here)
2. Oil cooler is leaking everywhere
And then the "while you are in there" list is as follows:
dual tensioner mod
IH Pump swap
203 t-stat
Gooch's coolant flush
Oil Change
The connections on the water pump are seeping anyway so I might as well change everything out.
NOW... the stupid stupidness part...
I have called just about every parts store in town (even the NAPA's and the other good non-chain stores) and no one even knows what SCA is and no one carries it.
I know I could use the green stuff and just add SCA but I'd rather have a non green coolant so as to remind people that it is not just regular stuff.
Grrr... and here is the kicker.... I am fairly sure that if I drive around to the various stores I could find it on the shelf. I can also order it from Amazon but it'll cost a bit more (might be worth it).
Amazon has the Prestone Heavy duty (AF977) for $17.50/gal. Plus, purple coolant is what all the cool kids have...
Richard
EDT: amazon supply has the six pack for ~$68... that's just over $11/gal
My injector cups have never been changed so the sealant on them can be dissolved by OAT's an I really don't want to do injector cups right now... I am looking at almost $1k in parts and tools for everything now.
Instead of paying someone for the AC flush, vacuum, and charge, I can get the tools my self for less than the service (about $190 in tools).
I can get a 6 pack of the Prestone AF977 from amazon supply for less than 4 of the singles....
Anyone in/near Tucson need some coolant? I'll have a couple extra gallons.
Richard
Have you looked for Fleetcharge coolant? That is supposed to be pre-charged as well and most of teh NAPA stores around here carry the stuff. I can't say if they do that all across the nation or not though. This is farm country, there are LOTS of diesel tractors!
http://www.napaonline.com/Catalog/Ca...058_0429168785
From what I'm seeing you can buy the Fleetcharge Coolant by the gallon (undiluted) and it is part number FAF FCA003
http://www.napaonline.com/Catalog/Ca...003_0424509935
Or as an alternative, you can get the premixed stuff and forgo the trip to Wallyworld for the distilled water and it is part number FAF FCA053.
http://www.napaonline.com/Catalog/Ca...053_0006545521
For my money I buy the undiluted stuff and a gallon of distilled water for about a buck. It's a better value that way and it ensures that you get enough coolant into the system after a flush.
here is where I found it for ~$11/ gal.... you just have to buy a 6pack...
I looked for fleetcharge but all I could find was the ELC stuff.
Prestone AF977 is actually purple according to all the docs, but I imagine it's a low silicate version of the green stuff with the SCA pre-added.
As it never freezes here I was thinking of running 3 gal of concentrate instead of 4 as in Gooch's procedure but I have not decided.
Richard
NAPA AUTO PARTS
NAPA AUTO PARTS
NAPA AUTO PARTS
I figured if I am going to have to order it, I might as well save the 2% sales tax and get it from Amazon cheaper....
Richard
Richard
So is that AF977 definitely NON-ELC?
just because they do not stock it does not mean they can not order it. it is a stock item in the warehouse.
