Seatbelt Buzzer ....
Old Jul 3, 2003 | 12:22 PM
Stingray42's Avatar
Stingray42
Hey all,
I'm trying to get rid of that horrible sounding buzzer for the seatbelt warning in my 1984 F150. Does andone know where the buzzer is located and if i remove it, will it affect anything?
Thanks!
Andrew
Old Jul 3, 2003 | 01:15 PM
Jens's Avatar
Jens
Hi Andrew,
the buzzer is located over your Glover Box.
If you have the buzzer in hand the best is to open the box. Cut the two thin wires and the buzzer won't work anymore. Put the buzzer back, otherwise you fasten seat belt light won't work also....
If you want a pic of that damn thing.....just drop a line
Jens
Old Jul 3, 2003 | 01:23 PM
PA F150 4X4's Avatar
PA F150 4X4
I would unplug the harness behind the seat
Old Jul 3, 2003 | 01:29 PM
Stingray42's Avatar
Stingray42
Jens- can u send that pic?
PA- What harness?
Thanks!
Old Jul 3, 2003 | 01:31 PM
Stingray42's Avatar
Stingray42
jens- wires in the glove box or buzzer box?
Thanks
Old Jul 3, 2003 | 01:33 PM
PA F150 4X4
There are wires that come from the seatbelt assembly and connect behind the seat with a pull apart connector that allows you to remove the wiring when you remove the seat. Unplug it and the buzzing will stop.
Old Jul 3, 2003 | 01:38 PM
Jens's Avatar
Jens
Hi
PA: yep, also a very good idea, much easier
Stinray, still want a pic?
Jens
Old Jul 3, 2003 | 02:04 PM
Jens's Avatar
Jens
Thanks
Sorry,
I mean the wires in the buzzer box
Jens
Old Jul 3, 2003 | 02:43 PM
Stingray42's Avatar
Stingray42
I just disconnected the buzzer negative power, and the buzzer is off, but the seatbelt light comes on still, which is what i wanted. is there a headlight or key buzzer in these?
Thanks
jmuenchow
Jul 9, 2015 08:22 AM
ddeflyer
Feb 10, 2015 01:58 PM
bills86f150
Dec 20, 2014 06:38 PM
79ranger150
Aug 4, 2014 08:19 AM
Ordnance
15
Feb 1, 2014 03:23 PM
