Cluster question
Old Mar 31, 2014 | 08:09 AM
coreyallan01's Avatar
coreyallan01
Cluster question
Question fellas, is the coolant temp gauge in our cluster replaceable? Mines stuck and only moves on occasion, senders good. If not and I'm forced to buy a whole cluster on flebay does the ecm tell the readout the milage or am i stuck w the used clusters milage? FYI, i have a post in the parts wanted section if applicable... Thanks.
Old Mar 31, 2014 | 08:15 AM
madpogue's Avatar
madpogue
You can replace just that segment, that contains the oil and temp gauges. LMC has them, or you might just find one on eBay. Might even be cheaper to buy a while cluster at the boneyard.
Old Mar 31, 2014 | 08:19 AM
helifixer's Avatar
helifixer
I have seen a couple times where the face of the gauge comes loose and sits on the pointer shaft which doesn't allow it to move. to fix it I just remove the cluster, remove the clear lens and center the face plate and than take a tooth pick and put a few drops of black silicon on the edges. let dry and re install.
Old Mar 31, 2014 | 08:21 AM
DIYMechanic's Avatar
DIYMechanic
Is it safe to assume you've already tried replacing the sending unit?
Old Mar 31, 2014 | 08:40 AM
coreyallan01
Thanks guys! Yeah, we tested the sender when we got the truck back from Arizona.. Currently the gauge won't zero out when the truck cools down and just stays at the N all the time except for the occasional movement.... I'll check to see if the face is sitting on it..
Ewaterfall
May 28, 2019 05:05 AM
pcman
Sep 20, 2017 03:07 PM
16falcon
Apr 23, 2007 02:12 PM
MRStace84
Jun 13, 2005 08:45 PM
blueoval66
Apr 23, 2004 08:25 AM
