brake controller
Old Mar 31, 2014 | 07:16 AM
invinciblefishing's Avatar
invinciblefishing
brake controller
Hi I have a 2012 F250 lariat powerstroke and recently got a new trailer with electric over hydraulic brakes and when hooked up to the truck the brakes will not work at all even with gain up to 10. I know the trailer is working because I hooked it up to my buddies 6.7 powerstroke. Now the weird part is my truck will work on trailers with electric brakes.
Old Mar 31, 2014 | 08:23 AM
wingedone's Avatar
wingedone
On my 13 there is an option for electric over hydraulic that you have to set on the truck.
Assuming you have done that, the brake controller is very different than even my 2008. It seems to be speed proportional, and you will notice more braking from the trailer as your speed is increased. Very little at very low speeds.
Finally, if all that fails, it's dealership time, while it is still under warranty..
Old Mar 31, 2014 | 08:54 AM
invinciblefishing
I do have it set to electric over hydraulic in the dash and there is no breaking at any speed. The truck has been to the dealer and has has the (tbc) trailer brake control module replaced. Still not working now dealer is saying that the light bar I have in the grille is effecting the brakes but it is not.
Old Apr 2, 2014 | 02:37 PM
C1776M's Avatar
C1776M
Not sure if you saw this thread or if it would help you out.
https://www.ford-trucks.com/forums/1...er-brakes.html
Old Apr 2, 2014 | 02:49 PM
djousma's Avatar
djousma
When you say "hooked up to the truck" what do you mean. are you standing still or rolling at all? EDIT: nevermind, I see in your second posting that you indicate you were moving.
What year is your buddies 6.7? It might seem silly, but why not disconnect the lightbar and see what happens? At least you can prove the dealer wrong, and send them back to the drawing board.
Old Apr 2, 2014 | 05:17 PM
senix's Avatar
senix
Ok...need to test for power at the back of the truck and see if you even have power.
Also have you tried any other trailers?
Old Apr 2, 2014 | 06:12 PM
Hdslider's Avatar
Hdslider
Senix. He has hooked up to other trailers.
Old Apr 2, 2014 | 06:48 PM
senix's Avatar
senix
I see that now.
Old Apr 4, 2014 | 08:13 PM
boatman33's Avatar
boatman33
I have a 2012 and a large trailer with electric over hydraulic brakes. when I first got the truck I could not get the brakes to work either. seems they don't work with all of the trailer brake acuators out there. I checked everything and was frustrated at first. after talking to the people who make the controllers I found out there is an interface you mount onto the trailer and the 2012 will work with your acuator. I put on the interface and a new acuator (mine was getting old and the newer version was better) now it works great. the original acuator I had was a carlisle and they were bought out by someone but I can't remember the name. I could find out the part # for the interface if you need it or the phone for the manufacturer.
Old Apr 6, 2014 | 05:57 PM
porthole's Avatar
porthole
I have a Carlisle pump and have no issues with it.
With your hydraulics, have you had someone step on the brakes and listen for the pump to run?
Old Apr 7, 2014 | 12:17 PM
boatman33's Avatar
boatman33
the pump would not run properly before the upfit. it was more of an electrical issue than hydraulic. they said a new acuator would probably work without the interface but definately would with it. (my old actuator was a previous generation and about 7 years old). I have another truck with a different controller in the cab and it wouldn't work with that truck so well either. the interface wasn't alot of money and I need that trailer everyday in the fall when I first got the truck. wanted it guaranteed fixed fast. thats what I got. everything is much better now.
elkarcher1716
2009 - 2014 F150
13
May 15, 2014 09:17 PM
wildfire68
Dec 24, 2008 02:13 PM
Brian0445
Oct 20, 2008 04:46 PM
the cleaner
Jun 30, 2008 09:21 PM
zhigaag
Jun 25, 2007 03:34 PM
