Sponsored by: Real Truck
brake controller
Old Dec 24, 2008 | 05:45 AM
wildfire68's Avatar
wildfire68
Question brake controller
Does the factory brake controller work elec/hyd disk brakes or just electric trailer brakes?
Old Dec 24, 2008 | 07:19 AM
powerstroke72's Avatar
powerstroke72
I had the same question not long ago. Here are the links to the two threads:
https://www.ford-trucks.com/forums/7...ic-brakes.html
Hope it helps.
Old Dec 24, 2008 | 02:13 PM
TexasRebel's Avatar
TexasRebel
The information from Ford mentions that the TowCommand brake controller is only shown to work with electric brakes, and not electric/hydraulic or surge brakes.
well, in my experience, the output required for electric and electric/hydraulic brakes are the same (maybe a little lower gain on the E/H)...so there is no reason that it shouldn't work. I haven't had the chance to pull a trailer with E/H brakes with a TowCommand yet, though.
and the surge brake thing is just a little redundant, IMO, because no brake controller works with surge brakes...that's the point.
The only way I can justify the TowCommand controller not working with an E/H system is if the required signal from the controller is brand specific. There may be a company out there that want you to use THEIR contoller with THEIR brakes.
