226 fuel pump change
Old Mar 30, 2014 | 06:39 AM
fordf348's Avatar
fordf348
Getting my f-3 ready for truckstop so I want to change out fuel pump and distributor vacuum pump to avoid problems. Any suggestions on how to get the fuel pump out and the new one in?
Thanks
Ed
near Philadelphia
Old Mar 30, 2014 | 08:10 AM
FortyNiner's Avatar
FortyNiner
There is an access panel on the inner fender. Take off the tire and remove the panel. With them out of the way, you'll have a clear view and reach to the fuel pump.
Old Mar 30, 2014 | 08:42 AM
Marauder2004's Avatar
Marauder2004
Well there's something I didn't know! Seems easier than leaning over into the engine compartment like I did last summer. Leaning was probably still less of a hassle than wrestling those big wheel nuts and rims off and back on though.
Old Mar 30, 2014 | 08:50 AM
FortyNiner's Avatar
FortyNiner
Yup. These beauties were designed with repair in mind.
Old Mar 30, 2014 | 09:20 AM
fordf348's Avatar
fordf348
Pulling the wheel off is what I was trying to avoid but it does look like the only way to do it........the heat shield over the manifold seems to block access from the top.....thank you, I will try it again today
Ed
Old Mar 30, 2014 | 10:05 AM
Jolly Roger Joe's Avatar
Jolly Roger Joe
It's almost impossible to get the left side nut onto the stud unless you pull the wheel off and remove the access panel. At least that's what I found.
Luckily, someone on FTE told me about this panel and removing the wheel.
Old Mar 30, 2014 | 02:36 PM
fordf348's Avatar
fordf348
Well installing the fuel pump is going along fine.....few things to put back before moving on to the vacuum pump on the distributer, many thanks for the tips, removing the tire was the only way to go.
Any tips on the vac pump?.......do you have to remove the breaker plate or can I wiggle the arm out of there?
Ed
Old Mar 30, 2014 | 02:40 PM
Marauder2004
I'll just add that I removed and installed the pump on my truck twice from the top before I knew there was an easier way. Yet another reason I love this forum!
Old Mar 30, 2014 | 03:31 PM
toby tough's Avatar
toby tough
I took mine off last week from the top.Probably go back in that way cuz I still have the WM's on. Don't want to jack around with them till I have to.
schmity
Mar 2, 2007 03:41 PM
