Weird engine noise
Old Apr 1, 2014 | 01:57 PM
BroncoRN's Avatar
BroncoRN
No coolant loss. I was losing some oil. And thankfully my noise doesn't sound like that. I'll see if I can get a video of mine.
Truck runs fine and I've always wondered where this noise came from.
Old Apr 1, 2014 | 10:59 PM
HiZ's Avatar
HiZ
Originally Posted by Kdr358
Does it sound like this? click the grey box and the Vid will play. If it sounds like that then you have big problems at hand.
I had pretty much the same thing with my old V10 It was burned #9 and #10 pistons. My truck saw a hard live with not so good service history. The truck was using about 2qts of oil every 1k miles so I figured it was a big issue.
Do you have any oil or coolant loss?
Is that really as loud as it sounds
Does the thing really sound like a diesel, Is it really as loud as that vid
Old Apr 2, 2014 | 10:24 AM
Kdr358's Avatar
Kdr358
Originally Posted by HiZ
Is that really as loud as it sounds Does the thing really sound like a diesel, Is it really as loud as that vid
Yes it was bad, but it would vanish within 60 seconds! That truck was driven into the ground by the railroad since new. It had just under 13,000 idle hours. 1hr = 33 miles so somewhere in the 460,000 miles of just idling wear and tear.
The back pistons were badly burned, the truck was ran hot quite a few times and probably low on oil a few times.
muddyford911
2004 - 2008 F150
Feb 2, 2016 04:24 PM
JohnOsky
Jul 27, 2010 06:32 PM
hvbarbie
1997 - 2003 F150
Jan 28, 2009 06:33 AM
hi-jacker
Nov 25, 2006 07:38 AM
mikeil888
Sep 27, 2002 01:28 PM
